New here with a simple question
Discussion in 'New Members' started by tacotimm, Nov 23, 2020.
  1. Nov 23, 2020 at 2:59 PM
    tacotimm
    tacotimm [OP] Active Member
    Tim
    Rockville, MD
    2017 TRD Off Road
    OME 2” suspension lift kit, MagnaFlow exhaust, TRD 17" Sema rims, Firestone Destination XT LT265/70R17, Bakflip, TRD air filter, TRD Pro grill
    I have a 2017 TRD Off Road. I have a simple question. I guess I can get more ground clearance by getting a leveling kit, and it might improve the look. As far as suspension lifts go, when people lift their trucks, do most people level them as well? And if you wanted to both lift and level, would you need a lift kit and a leveling kit or will some suspension lift kits also level the truck? I'm not looking to do this real soon. I'm just curious. Thanks.
  2. Nov 23, 2020 at 3:12 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Hey, welcome to TW!
    By leveling kit I assume you mean a small spacer lift?
    You can also level the truck with a suspension lift. When I finally get a suspension lift I am going to try to keep the rake though.
    If you choose to "lift and level" you do not need a lift kit and a leveling kit.
    You can adjust where the spring sits on your aftermarket shocks/coilovers to determine how high the front sits.
    The height of your rear end will be determined based on if you install an entirely new spring pack, or just a 1-1.5" add-a-leaf in which you would be adding adding leaves to your factory leaf pack. Some folks will just throw a block in the back. So to answer your question, a suspension lift can level your truck if you want it to.
    Some people do end up adding a small spacer to their suspension lift to address issues like the front end sagging after adding new amour up front.
    Most folks here do not recommend using a spacer lift if you off road frequently.
  3. Nov 23, 2020 at 3:18 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Nov 23, 2020 at 4:14 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Hobbs likes this.
  5. Nov 23, 2020 at 4:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Some. Relative to approach/departure angles and other body related clearances. However, you are still limited at the axle line, as that is not affected. Only larger diameter tires lift the axle line, by the increase in radius of the tire. Of course this also lifts the body.
    Yes.
    When you are, call Marie @HeadStrong Off-Road with how you actually use the truck, your goals and a budget. Install what she ships you.
    Welcome to TW, where we can spend your $ faster than a divorce attorney. Some of whom are likely in business because of us.
    boston23 and Hobbs like this.
  6. Nov 23, 2020 at 4:28 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
    buckhuntin-tacoma likes this.
  7. Nov 24, 2020 at 7:30 AM
    tacotimm
    Tim
    Rockville, MD
    2017 TRD Off Road
    Thanks! This is very helpful. I know you can spend a ton of money. I just bought the 17" Sema rims and now saving up for the tires which will be even more expensive. Next will be rock sliders. I want to take it off road. Then I'll think about the suspension, whether or not to keep the rake, etc.
  8. Nov 26, 2020 at 6:08 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! I think the main difference between lifting and levelling your truck is levelling is really just lifting the front a little bit to match the rear so the truck has zero rake.
