New HID Retro Group Buy Thread
Discussion in 'Group Buys' started by cummins6speed, Aug 23, 2011.
Thread Status:
Not open for further replies.
  1. Sep 26, 2011 at 4:01 PM
    #241
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    yeah i know, idk what to do about it. i emailed TRS because they are closed now.
  2. Sep 26, 2011 at 5:11 PM
    #242
    superwhite10
    Garner, NC
    well i think i figured it out. the bulbs are not tight inside the projectors. make sure when you guys install you get those bulbs TIGHT!
  3. Sep 26, 2011 at 6:54 PM
    #243
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    If that solved the problem then post some more pics of it at night
  4. Sep 26, 2011 at 7:20 PM
    #244
    superwhite10
    Garner, NC
    well i am not 100% sure. its hard to explain but i can push on the back of the bulb and that dark spot i said i was seeing moves. my bulbs are not tight inside the projector and i can change the light output jut by moving the bulbs. i will try to fix it asap but my next day off isnt until saturday
  5. Sep 26, 2011 at 7:30 PM
    #245
    09taco4x4
    Louisiana
    If that doesnt work go to HIDplanet.com and check out the tech page. I found a PDF instruction sheet on how to install MiniD2S projectors in late model Tacoma headlights
    Might be worth reading to make sure you didnt skip a step
  6. Sep 26, 2011 at 7:55 PM
    #246
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Hmm... I am not sure what you've got wrong here. First inclination is that your beam is aimed way too high... I will take a couple shitty cell pics in the morning when I go to work and post them into live. You can link them in here at that point. I am only 35w for now, and I am brighter than that. Take a pic of the back of your bulb with the plug removed as well as a shot with the light up against a wall.
  7. Sep 26, 2011 at 8:53 PM
    #247
    superwhite10
    Garner, NC
    ill look into that...
    im pretty positive its because my bulbs are not seated properly/tight enough. if i push the bulbs into the projector they get brither and the "black circle" im seeing goes away
  8. Sep 27, 2011 at 12:02 PM
    #248
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    bummer...i was just about to order too...I guess i'll wait for the next one (if there is one).
  9. Sep 27, 2011 at 12:11 PM
    #249
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    +1
  10. Sep 27, 2011 at 12:46 PM
    #250
    09taco4x4
    Louisiana
    They just waiting on that "Obama $$"
  11. Sep 27, 2011 at 12:48 PM
    #251
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    It's been around since before Obama.
  12. Sep 28, 2011 at 8:02 PM
    #252
    superwhite10
    Garner, NC
    so since i had been having trouble with my lights i emailed TRS with my problem and they emailed me a .pdf directions with pictures. i know there are some on here (since thats what i followed) but i found theres much more informative and i think i have fixed it. going to test now so i will follow with pics
  13. Sep 28, 2011 at 8:05 PM
    #253
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Can you upload the PDF? It might be helpful to all of us that are doing the retro. I for one I'm only slightly "scared" of the trimming part for the gatling gun shrouds... specially since my whole setup is going to be painted in black chrome, so no black paint to go over fuckups. But who knows, there might be info in the PDF that would be really helpful to some in the electrical department.
  14. Sep 28, 2011 at 8:48 PM
    #254
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    Hurry up!
  15. Sep 28, 2011 at 9:01 PM
    #255
    superwhite10
    Garner, NC
    low beams
    high beams
    before
    after
    buuutt..now..i need to take my passenger headlight back apart and clean the inside of the lens and fix the seal. its fogging up really bad and had some water in it early..and im working on getting that pdf uploaded. stupid winzip is taking forever
  16. Sep 28, 2011 at 9:02 PM
    #256
    meantaco
    Andres
    what a difference !
  17. Sep 28, 2011 at 9:02 PM
    #257
    superwhite10
    Garner, NC
    the pictures dont do them justice now. the difference in what they were before i fixed them is night and day. and it was MUCH MUCH easier to assemble it the RIGHT way than it was the way i had it
  18. Sep 28, 2011 at 9:23 PM
    #258
    superwhite10
    Garner, NC
    as requested. the .pdf file from TRS. these are the most in depth directions i have been able to find and they helped me fix mine as well as another member.
  19. Sep 28, 2011 at 9:26 PM
    #259
    I Liquid I
    Puerto Rico
    Thanks for the PDF! + Rep! :D
    That PDF is awesome BTW, very very detailed. Also, that CCFL insert was sick!
  20. Sep 28, 2011 at 9:27 PM
    #260
    superwhite10
    Garner, NC
    thank you sir i hope it helps! cant wait to see everyones finished work!
Thread Status:
