New howling increase with speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike06toyota, Dec 18, 2023.
  1. Dec 18, 2023 at 4:44 PM
    Mike06toyota
    Mike06toyota [OP] Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    Afternoon guys I have a new howling that is low and slight and will increase with speed sound like it just started all of the sudden, anybody got any good ideas on where to start?
  2. Dec 18, 2023 at 4:49 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Wheel bearing? Diff?
  3. Dec 18, 2023 at 5:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Tires?
    All Terrain and especially mud tires can be pretty quiet when new, but as they age it is impossible to get them to wear perfectly. The older they get the louder they become. You could also have an alignment issue or worn shocks which will lead to uneven tire wear, and the noise that comes with it.
  4. Dec 18, 2023 at 8:30 PM
    TacoTuesday1
    SD CA
    wheel bearings probably worn. Tires may be out of balance.
  5. Dec 18, 2023 at 8:31 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    If the sound does not change when the road surface changes, then chances are it is a wheel bearing.
  6. Dec 18, 2023 at 8:32 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    How many miles on the truck? Drive it on a dirt road and if the sound goes away then it’s the tires. If it doesn’t go away it may be front wheel bearings.
  7. Dec 18, 2023 at 8:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does the sound change when going into or out of a curve?
