New howling sound.
Discussion in 'Technical Chat' started by JJ04TACO, Mar 6, 2018.
  1. Mar 6, 2018 at 9:05 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    So I have a new howling coming from what I believe to be the rear of the engine/trans area. I suspect a bearing is giving up. But which one I have no idea. Could be in the trans.
    Tried to upload a video/audio with no luck. There is also a slight "grinding" sound kind of rough. The sound gets worse with increasing RPM's.
  2. Mar 6, 2018 at 12:43 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Common Issues (condensed)
    Possible lower ball joints, but if gets worse with RPM then probably not.
    If you switch to 4wd, does it go away? Needle Bearing
    If you steer one way the sound worsens and the other way it gets better? Wheel Bearing
    I see you are lifted. Driveshaft vibe?
  3. Mar 6, 2018 at 9:19 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Definitely rotational. Sounds similar to a throwout bearing on a manual trans. (This is my first auto trans vehicle) Steering pump is fine, whisper quiet. No wheel bearings for sure. It's all the time when stopped and idling increasing in pitch when RPM's increase. There must be a bearing somewhere thats slowly going. Maybe an input shaft bearing in the trans?
  4. Mar 7, 2018 at 1:35 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    If it's making noise while idling, I would suspect an engine component. Tensioner and Idler pulleys commonly go bad on all brands of vehicles. Could also possibly be alternator whining.
    Only other thing off the top of my head that would be a suspect is a Torque Converter issue.
    Sitting at idle with an Auto trans, the only parts spinning are engine components and the torque converter. Idling, nothing inside an auto trans is moving except the converter.
    JJ04TACO[OP] likes this.
