New HU with maestro help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crontegy, Feb 18, 2017.
  1. Feb 18, 2017 at 8:05 AM
    Crontegy
    Crontegy [OP] Member
    2014 DCSB TRD Sport
    Hey everyone, I have 14 Tacoma with JBL and I'm trying to get a 4200nex installed. The harness for the maestro does not appear to match up with the connections in the dash for existing HU. Has anyone done this install? I can't figure it out. Especially the amp adapter part of the harness. There is no matching connection. And one connection I'm supposed to make from the harness has no counterpart.
    Thank you!
  2. Feb 19, 2017 at 8:08 AM
    Crontegy
    2014 DCSB TRD Sport
    Going to bump this up to top with pics of the connections I'm having trouble with.
    This is the amp adapter that doesn't have a connection...
    This is the entire amp adapter...
    I don't know what this does but there is no existing connection in the truck for it...
    And these next two pics fit together but the connections obviously don't match up...
    Any help is very much appreciated! Thank you!
  3. Feb 20, 2017 at 11:51 AM
    Crontegy
    2014 DCSB TRD Sport
    Ok. Last chance to help me. :fingerscrossed:
  4. Feb 20, 2017 at 1:23 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I initially thought maybe there was a different wiring kit for JBL vs non-JBL. But plugging it in on Crutchfield's site, it says the harness kit works for both.
  5. Feb 21, 2017 at 9:38 AM
    tgear.shead
    tgear.shead Well-Known Member
    There is *DEFINITELY* a difference for JBL vs standard.
  6. Feb 22, 2017 at 3:56 AM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    Prior to '13 models, there was a difference between jbl vs non jbl. '13 models and older used a 20 pin plug (which is shown in your first picture.) '14 and newer use 2 plugs. 10 and 6. (Blue plug in your last picture is the 6 pin.) The harness you picture appears to be for '13 and older jbl.
    See here where I changed my '13 jbl to '15 jbl for pictures of the differences: Radio Harness Help Needed
    Only way I can see it working is to get the metra 70-1761 harness and rewire accordingly. However, you will run into problems. JBL systems are a bear to work around. Factory hu needs the amp, amp needs the factory hu to work properly. Aftermarket hu's will have to bypass the jbl amp.
