NEW ICON LIFT HELP? Input please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adequate, Mar 8, 2015.
  1. Mar 10, 2015 at 4:56 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Youll get a little more travel when used in conjunction with an aftermarket control arm.
    ICON has some pretty nice, pre-packaged kits available. The stage 3 should meet everyone of your needs and more.
  2. Mar 10, 2015 at 10:01 PM
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
    Whats wrong with having uni-ball UCA's by the ocean? Sorry noob here on that aspect.
    How much do the the Icon progressive AAL's add in height for the rear?
  3. Mar 11, 2015 at 11:47 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    About 1.5"
  4. Mar 11, 2015 at 1:05 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm running a stage 4 w/o CDC and Dakars in the rear. It all works together fine. Dak's will carry some weight, and they can be a little squeaky unloaded. I would do it just the same next time, but I'd probably add the CDC.
    And I'd go here: http://trdparts4u.toyotaofdallas.com/Scripts/default.asp. Ask for Barbara King.
  5. Mar 11, 2015 at 1:21 PM
    bigtaco06
    bigtaco06 Well-Known Member
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    Floor mats, shorty antenna, brute force hybrid front bumper, ICON stage 3, method double standards, 285/75/16 KM2's, cool stickers
    Stage 3 with tubular arms. Set it and forget it (expect for adjusting the CO's occasionally for spring sag). No vibes, no diff/carrier bearing drop needed.
    Spend the money get a aftermarket UCA and ext travel CO. You will be glad you did. Guys say you get a "little more travel" you actually get a pretty considerable amount in reference to what you already had. I love my ICON UCA's they are quiet and give me a great amount of flex and travel with no sway bar.
    I will eventually buy new leaf packs but my stockers with the progressive AAL are going to be worn out by then.
  6. Mar 11, 2015 at 1:35 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have extended travel upfront with Icon UCA's. In the rear I have Icon 2.0 resi's with the dakar leafs. I love the setup and Ive had no issues. The dakars a stiff without a load in the bed but I usually have alot of wieght. The Icon add a leaf wasnt enough for my truck.
  7. Mar 11, 2015 at 3:10 PM
    BigE
    Eddie
    PNW
    Isn't the stage 3 already an extended CO setup?
  8. Mar 11, 2015 at 3:16 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Yes.
    Stage 1 - Reg Length 2.5 CO & Rear 2.0 Non-Res
    Stage 2 - Reg Length 2.5 CO & Rear 2.0 Res + AAL
    Stage 3 - Ext Length 2.5 CO + Arm & Rear 2.0 Res + AAL
    Some vendors will do a "Stage 2.5" with the Arms, Ext Coilovers & 2.0NR rear shocks.
  9. Mar 11, 2015 at 3:22 PM
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    I agree Stage 3 should be evrything your looking for thats what I'm currently running Icon everything love it but probably gonna move to Dakars and revalve my shocks towards the end of the year as i added a bedrack recently and will be adding more wright to the rear of the truck
    heres my truck on the Stage 3 as it sit today
  10. Mar 11, 2015 at 3:32 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Sick looking truck! Good lift amount, nice wheels & tires - all ya need to be moving and groovin.
  11. Mar 11, 2015 at 3:34 PM
    epard
    epard Well-Known Member
    Ethan
    Ocala, Florida
    2012 DCLB TRD Sport 4x4
    Icon Stage 3 tubular UCA's
    sub'd
  12. Mar 15, 2015 at 6:23 PM
    CWMcTaco
    CWMcTaco Well-Known Member
    Dallas
    2011 TRD
    Icon all around
    OK Guys here's my choices, keep in mind I don't have extra weight and prefer a softer ride. I got the GB on the Icons for the front, now trying to figure out the rear. I'm leaning toward the OME since it seems to give the most lift (and decent travel). I have a friend who got this setup then had to add more leaves since he had a heavy rear bumper. I'm just not confident the Icon AAL with 1.5" lift will be enough... and ride well.
    Place your votes!
    Option 1: $534.85
    - $214.95 Icon AAL 1.5" lift (includes U-Bolts)
    - $319.90 Icon rear shocks (56503) 14.22x23.25 (9" travel)
    Option 2: $634.85
    - $419.90 Icon rear shocks (56503-EXT) 15.9x26.8 (11" travel)
    Option 3: $658.23
    - $412.30 OME Rear Springs 2.75" lift (CS047R)
    - $168.00 OME Rear Shocks (N182) 13.85x23.93 (10" travel) - These are on sale because they are getting phased out - the 60091 replaces them for $214.70, supposed to be firmer
    - $34.20 OME U-Bolts (OMEU53A)
    - $12.35 OME Fitting Kit (FK29)
    - $31.38 OME Bushing kit (OMESB108 x 2)
  13. Jun 27, 2015 at 3:01 PM
    CWMcTaco
    Dallas
    2011 TRD
    Icon all around
    Went with Option #1 and it' working great. I kept the overload springs and seemed to get 2" of lift. Ride seems fine.
