New ignition coils / grinding noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by PULVER7II, Jan 11, 2023.
  1. Jan 11, 2023 at 8:34 AM
    PULVER7II
    PULVER7II [OP] Member
    Forrest
    2003 Tacoma 4x4
    Hello everyone. Hoping I can get some insight on this issue.
    Replaced my spark plugs and ignition coils about a week ago after my check engine came on stating the problem. Switched all four out and fired it up with no issues. Once I took it on the road though, anytime I decelerated by downshifting, at around 2500 rpm, the engine (or something) makes a strange grinding noise. If I hold the clutch in or go below roughly 2500 rpm, it goes away. Any help is greatly appreciated.
    Thank you.
    2003 Tacoma 4cyl 2.4L 4x4 manual
  2. Jan 11, 2023 at 8:46 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you got a Video?
    PULVER7II[OP] likes this.
  3. Jan 11, 2023 at 9:12 AM
    PULVER7II
    Forrest
    2003 Tacoma 4x4
  4. Jan 11, 2023 at 9:15 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    It just started after you worked on it...didnt do it at all before?
  5. Jan 11, 2023 at 9:26 AM
    PULVER7II
    Forrest
    2003 Tacoma 4x4
    Correct.
  6. Jan 11, 2023 at 9:27 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    i cant hear it well enough...you double checked everything under the hood..it sounds like a rattle to me
  7. Jan 11, 2023 at 10:01 AM
    PULVER7II
    Forrest
    2003 Tacoma 4x4
    Yep. Just checked and some nuts fell off that weren’t tight enough. Will replace and see if it fixes it.
