New injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Falcon$, Jun 18, 2025.
  1. Jun 18, 2025 at 9:54 AM
    Falcon$
    Falcon$ [OP] Member
    96 Tacoma 2.4l 2wd
    Hey there, new to the site. 96 2.4l automatic 2wd 230k. Was running rough at idle, decided to replace injectors. Ran well other than idle. Replaced injectors, cups. It starts and idles fine, but as soon as i hit the gas it dies. So i replaced TPS, same condition. If i open the throttle very slowly, it will come up to speed fine. But just normal pedal operation and it dies. Have checked all connections, grounds. Any ideas what might have caused this? It ran fine before. Injectors are firing. Thanks guys for any suggestions!
  2. Jun 18, 2025 at 9:59 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What brand injectors?
    Aftermarket injectors are trash, junk, poor quality and rarely, if ever, have the correct flow rate.
    ControlCar, Falcon$[OP] and HondaGM like this.
  3. Jun 18, 2025 at 10:25 AM
    Falcon$
    Falcon$ [OP] Member
    96 Tacoma 2.4l 2wd
    I got them from A-Premium. They looked quality and matched the old ones exactly.
    HondaGM likes this.
  4. Jun 18, 2025 at 10:29 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Did you recheck all of your electrical connections? Sounds like a problem I had a couple weeks ago when I forgot to reattach the plug to my air-thingy that's between the air filter box and the air tube (can't recall right now the name of it). When I disconnected it I hung it behind the air tube so it would be out of the way (and out of sight!) and then promptly forgot about it.
  5. Jun 18, 2025 at 10:31 AM
    Falcon$
    Falcon$ [OP] Member
    96 Tacoma 2.4l 2wd
    Yes all connections are in place
    HondaGM likes this.
  6. Jun 18, 2025 at 10:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...It ran good except for idle before installing injectors,but want after...sounds like junk Injectors
    ControlCar, TnShooter and Falcon$[OP] like this.
  7. Jun 18, 2025 at 11:06 AM
    TnShooter
    Deogee
    STOCK
    You might try hooking up a scan tool and looking at Live Data as you give it throttle, see what your fuel trims do.
    When buying Fuel Injectors, you get what you pay for....
    You got 4 injectors for $50. (Sounds like you got what you paid for ......"Fuel Squirters" .......
    A good set will $200.00+
    I'd go with MotorWest, they seems to have a good reputation among the Tacoma Community. (Denso was OEM, they don't offer them any longer)
    https://motorwestperformance.com/pr...Bw7j-FQmD2a1M31_B2n3m2VysIpb7n6x7QXQ9_ihehVIV
  8. Jun 18, 2025 at 4:31 PM
    Falcon$
    Falcon$ [OP] Member
    96 Tacoma 2.4l 2wd
    Thank you TnShooter. Gonna look into that.
    TnShooter likes this.
  9. Jun 18, 2025 at 8:10 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Search for eBay/whatever injectors here
    you will find your solution
    my thread is out there(I got scammed too)
    great job replacing i. cups!!!!
    Falcon$[OP] and TnShooter like this.
  10. Jun 22, 2025 at 5:07 PM
    Falcon$
    Falcon$ [OP] Member
    96 Tacoma 2.4l 2wd
    Fixed! TnShooter was exactly right. Wasted $ on junk ass injectors. put the motorwest units in and problem solved. Thanks everyone for helping! Truck runs great!!!
    TnShooter, ControlCar and Travlr like this.
  11. Jun 22, 2025 at 5:25 PM
    TnShooter
    Deogee
    STOCK
    Nice.
    Good to hear it's back up and running.
