New Intake Tube
Discussion in '1st Gen. Tacomas (1995-2004)' started by kgw, Mar 21, 2017.
  1. Mar 22, 2017 at 1:12 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol this page updated like 20 posts in the time I was gone from the computer. That looks really clean. Total cost $80ish?
  2. Mar 22, 2017 at 1:13 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    $80-100 2 months waiting for tube form slow boat from china
    Dalandser likes this.
  3. Mar 22, 2017 at 1:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Any write up on the assembly? The only part that made me not so happy was the vacuum sensor stuff. Did you need to drill to make it fit? Or cut the aluminum?
  4. Mar 22, 2017 at 1:16 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    yep it was a perfectly smooooth tube that I shortened and drilled a hole in. Never did a write up
  5. Mar 22, 2017 at 1:17 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Doesn't sound too bad then. The grommets just go in the hole you drill - no welding?
    mechanicjon[QUOTED] likes this.
  6. Mar 22, 2017 at 1:17 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    :threadjacked: sorry OP
  7. Mar 22, 2017 at 1:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He would be alright with it I think. It's in the spirit of his original post.
  8. Mar 22, 2017 at 1:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I just bought a new one from the dealer in fact two one for the Tacoma and one for my 3.4 swap.
    I know I paid less then $100.00 for both
  9. Mar 22, 2017 at 1:27 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  10. Mar 22, 2017 at 1:33 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am pretty much to the point if I buy from the dealer i just sign the invoice and glance at the amount .
    Then just pay the monthly statement .
  11. Mar 22, 2017 at 6:36 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I paid $80.00 for the OEM tube. I removed the silencers and plugged the holes to clean it up. Made sure all stock vacuum lines are still being used. Towards the Airbox there is a small "J" Shaped plug. This is to catch any water if it makes it's way into the intake. I will never most likely subject my pickup to that much water but there for a reason. I saw that Airraid tube as well but the price wasn't great. Cool looking though!
  12. Mar 22, 2017 at 7:07 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Take your tube to a Muffler shop and tell them to use aluminized tube and bend you a close carbon copy. A good shop can replicate that pretty fast and it will be MUCH cheaper. You will have to drill and add fittings. A can of Black Krylon will probably cost more than the tube.
    butsack likes this.
  13. Mar 22, 2017 at 7:15 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Similar to the direction I was headed.
  14. Mar 22, 2017 at 7:29 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I installed one of these on my 99 Tacoma when I had it. It is designed to deliver more power. I never noticed anymore power but it dos clean up the engine bay.:thumbsup:
  15. Mar 22, 2017 at 9:32 AM
    #35
    kgw
    kgw [OP] Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Brain fade....The tube looks like it goes to the vapor recovery, not the PCV!
  16. Mar 22, 2017 at 9:33 AM
    #36
    mechanicjon
    Jon
    Scottsdale Arizona
    ? PCV doesn't hook to air intake tube/
  17. Mar 22, 2017 at 9:34 AM
    #37
    kgw
    kgw
    SoCal
    99 PreRunner
    It could be trimmed a bit, at the bottom, to make it less hassle to take on/off.
    Dalandser[QUOTED] likes this.
  18. Mar 22, 2017 at 10:46 AM
    #38
    rskoncepts
    rskoncepts Member
    2004 Tacoma Prerunner 2wd
    Gee this thread took off. I like the cheaper solution but don't like the metal tube which holds more heat. Could wrap it but more money and more work.
  19. Mar 22, 2017 at 12:11 PM
    #39
    kgw
    kgw
    SoCal
    99 PreRunner
    Cheaper is good, but here in CA the CARB certification gets me past the SMOG monsters :thumbsup:
    Dalandser and mechanicjon like this.
  20. Mar 22, 2017 at 4:21 PM
    #40
    mechanicjon
    Jon
    Scottsdale Arizona
    Aluminum tube, actually dissipates heat faster then the thick plastic/rubber and is always cool to the touch
