New Issue----Installed my new leaf springs and they are already almost flat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Jul 6, 2014.
  1. Jul 6, 2014 at 3:02 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    I installed my new leaf springs today from general spring and they are not arched the way I thought they would be. I was wondering it were normal for new leafs to sit like this.
  2. Jul 6, 2014 at 3:03 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Did you forget a pic?
  3. Jul 6, 2014 at 3:10 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Did u measure ride height before and after to see if you got any lift? or were u just going for OEM ride height? As long as you got the height you were looking for I wouldn't worry about it...
  4. Jul 6, 2014 at 3:16 PM
    Tjsingle26
    Tom
    PA
    Ok here is some more info, I replaced the stock leafs with general spring standard leafs, which are better than the toyota stock ones. I did gain about an inch on both sides.
    Here is some pictures.
    Drivers
    passenger
    It does ride a whole hell of a lot better, could it possibly the rear shocks as well?
  5. Jul 6, 2014 at 3:18 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    they are flat.... but not terrible. i would think new leaves that are "better" than oem wouldn't be flat
  6. Jul 6, 2014 at 3:22 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I think you have more problems than just flat springs, it's called rust.
  7. Jul 6, 2014 at 3:23 PM
    Tjsingle26
    Tom
    PA
    Its kind of frustrating because I read a lot of good reviews about general spring and like I thought that these springs would give me alot ore arch than that..
  8. Jul 6, 2014 at 3:24 PM
    Tjsingle26
    Tom
    PA
    The frame is fine, the pictures dont do justice, the bed was taken off not too long ago, and I was under there all day today.
  9. Jul 6, 2014 at 3:26 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    do have wight in the bed?
  10. Jul 6, 2014 at 3:27 PM
    Tjsingle26
    Tom
    PA
    Full tank of gas and thats about it. The shocks are the original ones though
  11. Jul 6, 2014 at 3:34 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Shocks don't provide any lift... Just springs. And as long as you retained proper ride height you're fine. More arch would mean more lift. If you don't want more lift those springs are fine
  12. Jul 6, 2014 at 3:39 PM
    Tjsingle26
    Tom
    PA
    I guess I just expected more arch because they were new, when the truck was up on the jack stands today the arch looked real good, the old ones were literally bent flat when they were even up off the ground.
  13. Jul 6, 2014 at 3:45 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    They are supposed to be like that. If they were arched way down with the weight of the truck on them they would provide no "spring" which would essentially be a hard-tail truck.
  14. Jul 6, 2014 at 3:49 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Thats how they live. These trucks don't have a typical leaf spring arch
  15. Jul 6, 2014 at 3:51 PM
    Tjsingle26
    Tom
    PA
    Thanks guys! I appreciate it! I thought I messed up.
  16. Jul 6, 2014 at 3:54 PM
    AR15xAR10
    No problem! :)
    Just did leaves on my buddies 09 and i thought they'd have a little more arch than the broken ones but it wasn't much. I guess that is toyota's secret to more flex :notsure:
    I can't complain, they work :)
  17. Jul 6, 2014 at 3:55 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    My ome lift springs don't have a huge arch but they still provide lift and support a loaded bed.
  18. Jul 6, 2014 at 3:56 PM
    Tjsingle26
    Tom
    PA
    This was my first time replacing them since I have had the truck so its all in the learning experience!
  19. Jul 6, 2014 at 4:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are fine, though depending how many miles you got and if you wheel at all I would strongly consider replacing those shocks. Especially if the new leafs gained you an inch worth of lift.
  20. Jul 6, 2014 at 4:05 PM
    Tjsingle26
    Tom
    PA
    The truck has 130K on it, I am not sure if thats alot for shock, but new ones are next up. I dont wheel quite yet, but I do go offroad for work a lot
