New issue
Discussion in 'Toyota Trucks & SUVs' started by carolbalzano, Jan 8, 2017.
  1. Jan 8, 2017 at 4:56 PM
    carolbalzano
    carolbalzano [OP] Member
    Carole
    2006 Toyota Tacoma TRD Double Cab V6
    So this is what I got. Regular scheduled maintenance should keep the truck going for a long time. If something wears out, replace it. Not a lot of other maintenance needed.
    What happened with my transmission is not common for Toyotas, but it can happen. Try to find a shop I can trust. Get a couple of opinions from a couple different shops. Learn everything I can about the issue. Etc.
    I have a new issue. The transmission has been fixed. $3,300. The truck still has a vibration. The shop said it's an issue with the tires. I had the tires balanced and rotated. Still vibrating. What could it be?
  2. Jan 9, 2017 at 6:21 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    When are the vibes showing up?..... at what speeds? Do they disappear at a certain speed?
    Need more info.
  3. Jan 10, 2017 at 2:32 PM
    carolbalzano
    Carole
    The vibrations are at 30 to 40 mph. After 40 mph, goes away. Two different kinds of vibrations. Getting worse as truck gets warmer.
