New jack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Dec 9, 2022.
  1. Dec 9, 2022 at 3:34 PM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    Whats a good aftermarket jack thats taller than stock jack, but still fits in oem jack space. With or without modification.
    JDKred likes this.
  2. Dec 9, 2022 at 3:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Why do you need a taller jack?
  3. Dec 9, 2022 at 3:41 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I have a floor jack that fits on the floor behind my seat along with jumper cables and work gloves
  4. Dec 9, 2022 at 3:50 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Don't over think it. Get some blocks of wood, a couple pieces of 2x6 6" long are not hard to find a place to store.
  5. Dec 9, 2022 at 4:00 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Out of my assortment of way too many jacks, the stock on board jack is the only apparatus I haven't used to lift the truck yet.
    I have a task this weekend.
    Tacospike likes this.
  6. Dec 9, 2022 at 4:08 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Dec 9, 2022 at 4:08 PM
    Tacospike
    Two Trucks
    Same. I’ve yet to use my stock jack.
  8. Dec 9, 2022 at 4:25 PM
    gudujarlson
    Minnesota
    I used the stock jack once when I got high centered on a muddy hill completed unprepared. I managed to get home using the stock jack and various prices of wood in the area.
    i otherwise carry a hi-lift with me on occasion.
  9. Dec 10, 2022 at 9:49 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    TireFire likes this.
  10. Dec 10, 2022 at 9:56 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Id be careful with floor jack left inside the cab, god forbid you get into a serious accident. That floor jack could scramble your yolk.
  11. Dec 10, 2022 at 9:59 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    The stock jack is just fine, and it is mechanical so no oil can leak out.
  12. Dec 10, 2022 at 10:16 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Will it lift my Taco if I get a flat? I have a TRD off road with TRD lift and 275/70/17 tires. I haven't been able to try it yet due to cold and snow here.
  13. Dec 10, 2022 at 10:21 AM
    wayne0
    wayne0 Well-Known Member
    Lift doesn't affect the jack as it's under the axle. You're fine.
    As said above, it's good to carry a couple of short pieces of 2x6's in case you need extra height.
  14. Dec 10, 2022 at 10:27 AM
    wayne0
    Trouble_The_Tacoma likes this.
  15. Dec 10, 2022 at 10:36 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    :thumbsup: Need that high-lift out in the elements to make it looks super cool. But my personal preference is to strap it to the bumper shackles just to add to the clucking noises.
  16. Dec 10, 2022 at 10:43 AM
    mutely
    Yes. It lifts from the axle on the rear, and you have not lifted the axle more than ~3/4”. On the front you do lift from a frame (ish) point and if you have a lift, that would moved higher. But as everyone else stated, carry some form of pad, like a block of wood.
  17. Dec 10, 2022 at 10:44 AM
    gudujarlson
    Minnesota
    You should always keep your hi-lift jack and shackles in your wheel wells. Exposing them to the elements makes them stronger.
    RIX TUX, Rock Lobster and 3JOH22A like this.
  18. Dec 10, 2022 at 10:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Unless you're in canuckistan, where your neighbor will snitch on you for having an assault rifle strapped to your hood.
    Steves104x4 likes this.
  19. Dec 10, 2022 at 10:48 AM
    gudujarlson
    Minnesota
    Unless you have increased the droop of the IFS, a lift makes no difference to the jack. Aldi barring perhaps a long travel kit, it’s not possible to increase the droop beyond the stock jack’s capability.
  20. Dec 10, 2022 at 10:55 AM
    TireFire
    Olympic Peninsula
    What are you talking about?? Nobody puts a lift without going up in tire size and that will definitely move the frame/axle further off the ground…
    But in most cases probably not enough to render the stock jack useless, especially with the scrap piece of 2x6
