New L3 kickers 10"
Discussion in 'Buy / Sell / Trade' started by JStradaXR, Sep 14, 2011.
  1. Sep 14, 2011 at 12:11 PM
    JStradaXR
    JStradaXR [OP] Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
    I have for sale a (2) NEW Kicker L3 solobaric for sale. i was going to use it but i went a different route. i can build you a box if you would like?
    here are the specs:
    10" Dual 4 Ohm Solo-Baric L3 Series Subwoofer
    Power Handling:
    • Peak: 800 watts
    • RMS: 400 watts
    Impedance: Dual 4 ohm
    Patented corner-ribbed, double-stitched Santoprene rubber surround
    Stamped steel basket protects massive internal motion
    Titanium deposit impregnated cone with rolled outer edge
    Vented 360° back bracing
    Rear foam gasket
    Heat-dissipating, solid pole piece and high-temp coil wire for longer woofer life
    Spring loaded terminals
    Poly-cotton semi-progressive spider
    Heat-dispersing, solid pole piece
    Spiralead tinsel leads
    High-temperature dual 4 ohms voice coils
    Sensitivity: 85.3 dB
    NEW in the box!
    asking $140 shipped.
    Or 2 for $250
    retails for 199.99 check it out
    http://www.crutchfield.com/S-AgA4D7gy8Z3/s_2061S10L32/Kicker-Solo-Baric-L3-Series-11S10L32.html
    this is a steal for the price
  2. Sep 14, 2011 at 12:51 PM
    mhenson327
    mhenson327 Active Member
    riverside ca
    2011 tacoma dc
    3inch lift I inch block 17inch method wheels bfg all terrains magnaflow exhaust
    How deep are they? Will they work good in a double cab taco
  3. Sep 14, 2011 at 1:08 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    E-mail the guys at SuperCrewSound.com they told me that they can customize, cut a square hole, one of their boxs for these subs as long as it's a second gen. Also there boxes are very high quality I've had 3 made by them all very good products with great customer service backing it. Have a 4th one coming now supposed to be here tomorrow! GLWS OP.
  4. Sep 14, 2011 at 1:25 PM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    I don't have a DC so I wouldn't know personally. I have a access cab...
    These things are awesome !!!
    Let me know...
    Thanks
  5. Sep 14, 2011 at 1:25 PM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    There ya go, thanks for the info bud! I appreciate it
  6. Sep 14, 2011 at 7:39 PM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    bump for a steal of a deal
  7. Sep 15, 2011 at 11:51 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Bump......
  8. Sep 20, 2011 at 1:46 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Bump bump bump
