New Leaf Install Im Working On.........
Discussion in 'Suspension' started by ETaco23, Nov 6, 2010.
  1. Nov 6, 2010 at 8:49 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    My buddy/neighbor has a 96 Tacoma with a 3" lift, and 2" body. He needs new leaf packs bad, and so he baught some ProComp Lift springs that give 3.5" lift.
    So Ive been helping him out, and let me tell you! Its the biggest bitch in the world! I had to cut 3 bolts off. and finally got the OEM leafs out. We got the Drivers side almost complete, and Tomarrow we need to get a new bolt, then finish the passenger side.
    I NEVER want to do this job ever again! :D
  2. Nov 6, 2010 at 8:55 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Afraid of work ehh........
  3. Nov 6, 2010 at 9:15 PM
    ETaco23
    Evan
    PNW
    No! not affraid... this job has just been a big PITA, thats all. Cant wait to be done!
  4. Nov 6, 2010 at 10:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, sometimes it can be a bitch getting those front ones out. I've seen where sometimes it takes a torch to burn the old rubber bushing out. :eek:
  5. Nov 6, 2010 at 11:15 PM
    ETaco23
    Evan
    PNW
    wow! yeah thats the one bolt that gave the biggest headache. one side came out fine while the other took like an hour of cutting and hitting, then I finally just broke it.
    Gotta go find a replacement now...:(
  6. Nov 7, 2010 at 9:46 AM
    JML50
    JML50 Well-Known Member
    Being its a 96 its no surprise you had to cut some bolts. Changing leafs on something newer is still tough but not much of a PITA.
  7. Nov 7, 2010 at 8:38 PM
    ETaco23
    Evan
    PNW
    Well today we finished it all up, and the Truck is sooper high in the rear now. We descided to put a few hundred pounds in the bed, its more like 300.....
    Try to get the springs to settle a bit. But how much should we expect them to settle? 1-2"s?
    Right now ide say the back is 2-3"s higher.
    Thanks for any help......
