New Leaf Pack's with 5100
Discussion in 'Suspension' started by mromeo, Dec 8, 2014.
  1. Dec 8, 2014 at 1:23 PM
    mromeo
    mromeo [OP] Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    Hey guys, so a couple months back I ordered 5100's all around, and am going to be putting them on in like 2 weeks. I've been noticing my rear leaf is looking flat and beginning to sag. What are good leaf packs that work with the rear 5100's?
    I was told the OME Dakars wont, because they require extended travel shocks. Any advice would be great.
  2. Dec 8, 2014 at 1:28 PM
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
  3. Dec 8, 2014 at 4:33 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
  4. Dec 8, 2014 at 4:36 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Toyota leaf springs are a flat design. If they are flat, you're in pretty good shape. If they are obviously frowning down over the axle, then yeah you probably want to replace the entire pack.
  5. Dec 8, 2014 at 4:43 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    ok cool I didn't know that, so in that case an AAL would be the better bet, how big of an AAL can you use with the 5100's? I like that Icon kit, just wonder if it will make everything level with the 885's/5100 im putting on
  6. Dec 9, 2014 at 4:18 PM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    Im running the same thing. 885s and 5100s all around. I used the toyotec add a leaf. It made it just about level all around. Some slight squeak after a few months but overall im satisfied.
  7. Dec 9, 2014 at 8:04 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    How hard was the AAL to install?
  8. Dec 10, 2014 at 8:21 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    You will like the Icon AAL more than the standard single leaf AAL that others offer.
    Icons pack is made up of three thin leafs, so you gain the height with out a huge increase in rate making the ride terrible.
    Icons kit is fairly simple to install, it bolt directly to your stock pack.
  9. Dec 10, 2014 at 8:31 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I am planning on going with Wheeler's 5-pack (maybe removing a leaf) with 5100s and OME coils in the spring. Put the tax return to good use!
    Towed ~5000 lbs the other day and had another 700+ in the bed and saw just how bad the back end sagged with the stock 3-leaf pack. Plus, it'd be nice to have a little bit more height.
  10. Dec 10, 2014 at 12:55 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    That'll work with 5100's right?
  11. Dec 10, 2014 at 3:57 PM
    thelivestone
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    I had a shop do it. I had never messed with leaf springs before and when i tried, it was a bit tough for me doing it by myself. I have very little mechanical expirence.
    If you good with that sort of thing then it really isnt that hard of a task to accomplish. But i paid like 300 and got everything put on at the same time and just picked my truck up afterwork. That was just alot easier for me.
