New Leaf Springs Are Sagging
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02RedDoubleCab4x4, Jan 9, 2022.
  1. Jan 10, 2022 at 7:43 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You take the block out and the sag will still be there. It's still the same point of contact whether on the block or the axle.
  2. Jan 10, 2022 at 7:48 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Except your point B is wrong. The point where the leaf spring meets the mounting location is the same point, whether it be the top of the block or the top of the leaf spring perch.
    Additional space (made by the block) between the actual axle and the leaf spring will cause other problems, yes, we can all agree on that. But blocks are NOT the cause of the sag in the leaf springs.
    Duckinatruck and 0xDEADBEEF like this.
  3. Jan 10, 2022 at 7:48 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    1000% agree
  4. Jan 10, 2022 at 7:54 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Can't argue with that. Add a 4" block nothing about the geometry changes? Perfect.
  5. Jan 10, 2022 at 8:20 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    I'm no suspension geometry expert, but it seems like the springs don't have enough lifting force to actually lift the rear end. So the spring main eye stays at the same height, but the center of the spring is then pushed up a couple inches. Something like the Dakars would have enough lifting force to push the main eye up.
    skeletron likes this.
  6. Jan 10, 2022 at 8:22 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The 4" block does not change anything about the geometry in the context of this discussion. "Points A, B, and C" all remain the same, regardless of whether there is a block in there, or not. Point B is actually the bottom of the leaf pack where it meets the mounting location. NOT the axle it's self.
    Lift blocks will cause more leverage front and back and side to side. They will not change anything up and down.
    Lift blocks will cause more axle wrap
    Lift blocks can have premature failure of U-bolts
    Lift blocks add ride height without giving you added suspension travel (particularly up travel)
    Lift block (dovetailing on the above point) don't give you a better ride quality
    Lift blocks can make your truck track wrong
    Lift blocks are often cheap and have been known to fail (split)
    Lift blocks, how ever, do not cause leaf springs to sag like in this picture (and the context of this discussion). The weight of the load is setting on the point of the leaf spring that contacts the mounting surface, which doesn't change between block or no block.
    Duckinatruck likes this.
  7. Jan 10, 2022 at 8:28 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    But a and c are not fixed points. They depend on the height of b.
  8. Jan 10, 2022 at 8:29 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    The body of the truck is *suspended* by the springs; that is why a 3 inch block provides 3 inches of lift. Along the vertical axis, the geometry remains the same. The vertical distance between the line connecting points A and C and point B is determined by the spring itself. If the spring rate remains constant, then increased weight is required to make the spring flex more. What changes is the distance between the plane of the spring and the rotational axis of the axle. THat is what accounts for the increased propensity for axle wrap.
    Edit:
    Try this experiment.
    1. Measure the distance from the hub to the fender on each side.
    2. After safely chocking the front wheels, jack the rear end by lifting from the center of the rear axle housing; alternatively, jack each side the same amount by lifting from the axle housing.
    3. Repeat step 1; the measurements should be the same, but the distance from the ground to the fender will have increased by the amount you raised the truck.
    With respect to your conceptualization of points A, B an C, by lifting the truck from the axle, you accomplish the same thing, in principle, as lifting the spring with a block.
  9. Jan 10, 2022 at 8:52 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It does not matter I have seen that very same thing before .About 6 months after the install
    I just went by the pictures I did not see the pictures were the day the springs were installed
    Perhaps a mislabeled steel order?
  10. Jan 10, 2022 at 9:01 AM
    AmherstAndy
    Andy
    Masshole
    I think it's possible that consistent, excessive axle wrap (both during acceleration and deceleration) caused by excessively tall lift blocks could prematurely wear the springs and cause them to frown. This leads back to lift blocks fundamentally causing problems due to axle wrap.
    Question for the forum: do lift shackles also cause increased axle wrap? I think I read somewhere that they do, but how could this be true if distance from the spring mount to the rotational axis of the axle remains the same? I think we all probably agree that the best way to achieve rear lift is with more spring rate.
    Bivouac[QUOTED] likes this.
  11. Jan 10, 2022 at 9:14 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    For @02RedDoubleCab4x4
    On my 2002, I had a leveling kit installed. The back was lifted with extended shackles, using the stock leaf springs. Within 6-12 months, I was replacing my rear springs with a set of Dakars due to my OEM springs looking like yours. So, no, new springs should not do this.
  12. Jan 10, 2022 at 3:11 PM
    staytru28
    staytru28 Member
    AZ
    2002 Tacoma SR5 V6
    Def not normal. I’m backing up the others in the thread. Look for OEM or better if able to. Good luck!
    Mark77 likes this.
  13. Jan 10, 2022 at 4:09 PM
    snaggs
    snaggs Well-Known Member
    Shaun
    Nova scotia , Canada
    2001 tacoma sr5 2.7 4x4
    None
    Springs cant support weight of vehicle, definitely not right.
  14. Jan 10, 2022 at 4:14 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Maybe you got reg cab springs, and you have a DC. It is quite common for upper leaves to conform to the overload, and that overload is way negative arch (like stock).
    If you put a flat (but shorter) overload in there, it will support the upper 3 leaves better
  15. Jan 10, 2022 at 4:21 PM
    #35
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    OP i'd check a toyota yard for some spares
  16. Jan 10, 2022 at 4:25 PM
    #36
    Bishop84
    Bishop84 Well-Known Member
    4" Block sucks, get a refund and get better springs.
    Ideally you should get a HD leaf spring and add just a 1" block.
  17. Jan 11, 2022 at 6:11 AM
    #37
    02RedDoubleCab4x4
    02RedDoubleCab4x4 [OP] Well-Known Member
    Sumter, SC
    02 Double Cab
    Rough Country 6", 2" blocks, 3 Inch Body, 15x8 with 35x12.50 General AT2
    For all the replies that stayed on the question asked thank you. Many replies were a tangent debate on lift blocks; which was not the question presented. For the record the blocks are 2" not 4". Stock shackles, I do have new shocks to install however the shocks are in one country in my garage and the truck is currently in another country for a couple more months. I am inclined to agree with one reply that stated I may have ordered extra cab springs and my truck is a double cab. I will check into Dakar springs that offer a 2 inch lift over stock height. My concern is that the lift springs may be a stiff/harsh ride. I am in my mid 40s and I am beginning to care more about ride quality.
    Good day to you all; enjoy your Tacoma no matter the generation!
    308savage and skeletron like this.
  18. Jan 11, 2022 at 6:26 AM
    #38
    02RedDoubleCab4x4
    Sumter, SC
    02 Double Cab
    And the winner is ARCHIVE ; I looked the parts numbers up on sd truck springs website and both springs are for an extra cab :frusty: .
    The more confusing question is why does the reg cab and double cab have the same part number :notsure:
    Extra cab https://www.sdtrucksprings.com/inde...MItY6J9PCp9QIVg8DICh2kYw2_EAQYBSABEgLBJPD_BwE
    Reg cab and Double cab https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=9636
    ARCHIVE[QUOTED] likes this.
  19. Jan 11, 2022 at 6:35 AM
    #39
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    That block is also killing them too.
  20. Jan 11, 2022 at 6:36 AM
    #40
    OpeCity
    Long Beach, CA
    It’s not, though
