New leak day!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mayonayze, Oct 31, 2019.
  1. Oct 31, 2019 at 6:18 AM
    Mayonayze
    Mayonayze [OP] Well-Known Member
    so exciting!!! There is rain water hitting the driver side floor board by way of the hood release lever. I looked up in there, and although i can’t see the exact source, it’s coming from somewhere above the fuse box. Any ideas?
  2. Oct 31, 2019 at 6:21 AM
    soggyBottom
    soggyBottom Well-Known Member
    Do you have any aftermarket wiring through the firewall?
  3. Oct 31, 2019 at 6:22 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    That’s where a lot of fire wall penetrations are, I’d think the linkage going to the break booster but it could be anything
  4. Oct 31, 2019 at 6:25 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Clean the leaves and or debris off from the top of the cowl.
    Bleep100 and Tainted like this.
  5. Oct 31, 2019 at 6:32 AM
    Mayonayze
    HA!!! Soggybottom...fitting. No aftermarket wiring or other new pushes through the firewall
  6. Oct 31, 2019 at 6:57 AM
    Tainted
    Tainted Well-Known Member
    Did you mess with the pinch weld?
    Beerpayzdabillz likes this.
  7. Oct 31, 2019 at 3:59 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Any chance you have a sun roof.??? Each corner of the sun roof has a drain tube. Open the roof the check for crap plugging drain...
    :thumbsup: Good luck
  8. Oct 31, 2019 at 5:25 PM
    Mayonayze
    No sunroof and no messing with welds. No modifications have been made up front. I did have the factory roof-rails removed, but i am not sure i can trace a good path from those roof grooves to the hood release latch area...
    Strange days...
  9. Oct 31, 2019 at 5:28 PM
    ICU1
    ICU1 Well-Known Member
    Then my guess would be, OP has a holy Tacoma
  10. Oct 31, 2019 at 5:34 PM
    Mayonayze
  11. Nov 1, 2019 at 11:17 AM
    over60
    Muskoka, Ontario
    Pull the weather strip and silicone those bolts. Or let the monkeys at the dealer try to figger it out..!!:fingerscrossed:
  12. Nov 1, 2019 at 11:31 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I'm guessing since you removed roof rails, water is making it's way to A- pillar, and coming out by hood latch. As over60 mentioned silicone the rail holes.
    Chew likes this.
  13. Nov 1, 2019 at 11:36 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
  14. Nov 1, 2019 at 1:14 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You ever seen a taco without a hole?o_O
  15. Nov 1, 2019 at 1:18 PM
    ICU1
    I know right. Have you seen those frames. We’re talking Sainthood.
  16. Nov 1, 2019 at 2:57 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Swing and a miss... :)
    Was that intentional?
  17. Nov 2, 2019 at 6:50 AM
    Mayonayze
    I assume removing the weather stripping and reinstalling is fairly straightforward, but anytime i assume that, the work ends up being a shit show. If anyone has any tips and/or pointers for this operation, please let me know.
  18. Nov 2, 2019 at 6:55 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Tracing water is as easy as keeping track of homeless people. Always taking the path of least resistance. It's impossible to follow. Just think what you did differently and start there
  19. Nov 2, 2019 at 7:08 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    They peel right off, make sure you have new and good double sided tape. You need to plug the holes beneath, and I can't believe whomever removed the rack didn't do this! Call and complain, also look for new shop.
    Mayonayze[QUOTED][OP] likes this.
  20. Nov 2, 2019 at 7:11 AM
    RushT
    North Texas
    You can buy the stock Toyota stickers that cover the holes when you don’t have rails. They’re like $2 or $3 each I think. Nice, heavy and durable.
    Mayonayze[OP] likes this.
