new Led dash lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mud Town, Mar 13, 2012.
  1. Mar 13, 2012 at 10:14 AM
    Mud Town
    Mud Town [OP] New Member
    Dan
    Appleton, WI
    2010 4-door six speed stick green
    Rim, Tires, grill inserts of teflon coated ten mesh.
    I solder different color LED on my cluster. And after I did this my key fob dose not work and I have three dash lights on. Traction control and air bag are two of them. Has any one else done this mod and had problems? our can anyone help me out.
  2. Mar 13, 2012 at 4:12 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    LED are polerized. Did u put them in the right way? Key fob might be the small battery or a fuse, engine bay.
    If 3 work that means the LED's are not properly connected, reversed, there is a problem with the harness, or the temperature was too high and you wrecked/shorted the LED's installing them.
    Make sure to check all of your fuses and disconnect your battery before attempting any mods.
  3. Mar 15, 2012 at 5:38 AM
    Mud Town
    Dan
    Appleton, WI
    thanks
  4. Mar 27, 2012 at 12:04 PM
    Mud Town
    Dan
    Appleton, WI
    yeah i put them on right. thinking of it being a clock spring. anyone know about that?
  5. Mar 27, 2012 at 1:20 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    it took me a few tries but I got mine right eventualy. some had a bad connection, some were soldered in reverse. If one led is backwards or doesnt have a good connection then none of them will work in that series.
    clockspring only affects the airbag and does not apply to the 2010
  6. Apr 1, 2012 at 11:47 AM
    Mud Town
    Dan
    Appleton, WI
    All of the lights work that i put on. just the air bag light and track light are on now. some one had said about it may be the clock spring, but i thought the truck was too new for the wires in the clock spring to crack. i think i will have to stop by the toyota dealer ship and have them hook up the truck and give me a better idea of what may be going on with this dam thing. i have'nt had much time to look at it, my mother had a stroke and all my time is being spent with her. i can just look on the computer from her room. so when i can work on it i hope to have a good idea of whats up. thanks for all the help. Dan
