New leveling suspension done, but more questions?
Discussion in 'Suspension' started by Outdoors yota man, Sep 30, 2023.
  1. Sep 30, 2023 at 2:13 AM
    Outdoors yota man
    Outdoors yota man [OP] Active Member
    2011 toyota tacoma pyrite mica
    I just got new bilstein 5100 front preassembled shocks/springs with 2 in level and bilstein 5100 rears. I love stance now and it lifted front considerably. However, now the front is 1 inch higher than rear. I am getting an alighnment next week.
    Will the front settle a little over time? Does my rear need to be a little higher than the front if i tow a 18ft boat from may thru first week of oct 20 to 50 miles at a time?
    Should i consider a 1.5 in add a leaf in the rear? I was looking at the icon add a leaf for this.
    Also, i am running 265 75 16s. Should i consider 285s? I would love the look of it? I am pretty certain they will fit. Maybe minor trimming. Do i need new uca's if i put 285s and aftermarket wheels? Can i just use stock? Will i notice significant difference in gas mileage and power when towing ? Sorry for all the questions. I am a rookie. Thanks
  2. Sep 30, 2023 at 2:58 AM
    Outdoors yota man
    Also, will my new front settle a little over time? Maybe i dont even need the add a leaf?
  3. Sep 30, 2023 at 3:36 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Your front will settle a bit. I would go full leaf pack, like icon rtx in say stage 2. The 3 leaf 1.5 to hold up over time. I had them and then switched over to full pack. 285's will drop your mile quite a bit, plus a bit of trimming and possible cab mount chop. UCA are needed over 2" in front for good alignment numbers. If you did go 285's with aftermarket wheels stay close 0 offset. I personally wouldn't. Most regear to compensate for loss of power due to that tire size. Just my opinion. Sure others will disagree.
  4. Oct 2, 2023 at 5:01 AM
    Jstocks
    Jstocks Member
    2023 Tacoma Double Cab 4x4
    can you adjust them down a notch in the front?
    I’m looking at putting a similar type setup on my truck and I’m new to this type stuff.
  5. Oct 2, 2023 at 6:34 AM
    Outdoors yota man
    I could however i would have to pay a mechanic to take it all apart, springs and all to lower it. So im not really wanting to do that. Just weird it raised it that much. I think im going to do the 2 inch add a leaf in the rear and i can do that myself
  6. Oct 2, 2023 at 6:37 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Drive it a couple weeks and then remeasure then make decision.
  7. Oct 2, 2023 at 6:45 AM
    Jstocks
    Jstocks Member
    I plan on putting a winch bumper on mine, so maybe the weight would pull it down some? you have yours on the last notch?
    I can get a full set for $400 so I was thinking of getting them.
  8. Oct 2, 2023 at 9:28 AM
    Outdoors yota man
    I got the preassembled bilstein 5100 with spring set at 2 inch 85 spring. They were all saying id get 1.75 to 2 in. My truck certainly rides alot better. I am going to get 2 in add a leaf in rear and ill be able to fit 33s.
  9. Oct 2, 2023 at 9:28 AM
    Outdoors yota man
    And yeah new bilstein 5100s on all 4 corners
