new lift / 2 questions
Discussion in 'Suspension' started by lizard1, Jun 25, 2012.
  1. Jun 25, 2012 at 3:27 PM
    lizard1
    lizard1 [OP] Well-Known Member
    Tucson
    Desert Sand Mica/4x4 off road w/lock rear
    Leer cap, rear TSB, BFG All Terrains 10 ply 265/75/16, mud flap trim, black badges, AFE filter, 3" Toytec lift, 884 OME coils, add - leaf, Bilstein 5100 all around
    Tacoma: '08 4x4
    Bilsteins 5100's installed yr ago - set at 1.75"
    Will be buying OME 885 front coils (Toytech site indicates 2'' lift).
    1. Should the Bilsteins be adjusted to 0'' ?
    2. Do I need to purchase the 1/4'' spacer from Toytech - if so, just 1 or 2 total?
    I'm new at this and want to do it correctly, at least buy the correct parts. I do not want to exceed 3''. My plan is 2" of lift.
    Thanks in advance to the lift experts on this site.
  2. Jun 25, 2012 at 5:28 PM
    Large
    Large Red
    1: Yes
    2: none if you are going with 885s, they give over 2" of front lift.
  3. Jun 25, 2012 at 5:29 PM
    Large
    Large Red
    Ok saw you are an access cab and have posted a thread similar to this already. Use. 884s, bilsteins at "0"
  4. Jun 25, 2012 at 5:30 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    U might need a top plate spacer for the drivers side
