new lift bigger tires = weak braking??
Discussion in 'Wheels & Tires' started by dollabill415, Nov 16, 2011.
  1. Nov 16, 2011 at 1:24 PM
    dollabill415
    dollabill415 [OP] Well-Known Member
    i have 2011 dclb trd sport and recently went from my stock 265 65 17 to 285 70 17 and now i feel like its taking me alot longer and alot more pressure on the pedal to stop my truck...especially when i have passengers or a load in the back... any suggestions that wont cost me thousands of dollars? does trd make a better brake pad by chance? lemme know please anything will help thanks alot
  2. Nov 16, 2011 at 1:29 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Rear brake proportioning valve probably needs to be adjusted. How much lift do you have in the rear? I know bamf makes one but I don't know if it works with second gens although the design cant be too much different. Should run you $25
  3. Nov 16, 2011 at 1:29 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    you can try stainless steel brake lines. that will at least make the brake pedal feel less squishy.
    others can speak better to this, but i think the next step would be a better brake pad and then a higher performance rotor.
    really, for the cost, just leave extra space between you and the car in front of you. after i lifted my truck, i found myself driving slower and not as worried about the increase in braking distance.
  4. Nov 16, 2011 at 1:35 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You can go higher perf brakes. High performance brake pads have an annoying tendency to have more squeal though.
    I'm running 285/70R17 and I can pretty much lock up my 2011's brakes at will - but I'm a regular cab.
  5. Nov 16, 2011 at 1:35 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That's a first gen mod.
  6. Nov 16, 2011 at 1:37 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    pads and rotors
  7. Nov 16, 2011 at 2:09 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If it were me, I'd start simple, bleed my brakes and make sure that's not the issue (doubtful that it is but it's the cheapest thing to try before dropping a lot of money on mods). Next, I'd try swapping to stainless steel brake lines. They seem to make a big improvement since they don't swell like the rubber hoses and force the pressure to be put to the caliper rather than lost expanding the hose. Lastly, I'd upgrade the pads and rotors.
  8. Nov 16, 2011 at 3:44 PM
    dollabill415
    yea i have been leaving TONS of room like u said...i guess it makes me a better driver thanks for the input
  9. Nov 16, 2011 at 3:47 PM
    dollabill415
    thanks for the step by step this sounds like a good route
  10. Nov 17, 2011 at 12:24 PM
    malander
    max
    01 limited trd 4x4
    Do 2nd gens not have a lspv? If so how do they differentiate braking power?
  11. Nov 17, 2011 at 12:31 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    (lift= added weight)
    (big tires= added weight)
    = more braking force.
    Mush Mouse likes this.
  12. Nov 17, 2011 at 12:37 PM
    Pugga
    Massachusetts
    A lift alone will not affect braking force if everything else is kept stock. The components of a lift are not that heavy. Lifting may affect how easily you can control your braking though since you'll have a higher center of gravity.
  13. Nov 17, 2011 at 12:40 PM
    tacobo670
    Ray
    Las Vegas
    ...with rims n tires?
    higher center of gravity, probably gonna feel more pitch/roll in body.
  14. Nov 17, 2011 at 12:43 PM
    Pugga
    Massachusetts
    I was just commenting that a lift all by itself, with nothing else done to the truck will not affect braking. The pitch/roll will depend on the lift as a lot of the lifts use much stiffer coils and keep the truck flatter in corners and resist the brake induced nose dive much better than the stock coils.
    Going to bigger rims and heavier tires will have a much greater impact on braking vs. just adding a lift. More rolling momentum makes it a lot harder to stop.
  15. Nov 17, 2011 at 1:00 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you need to upgrade your brake pads. stainless steel lines will only make your pedal feel firmer not improve braking distance.
  16. Sep 12, 2016 at 7:02 AM
    Lilcarkid
    Lilcarkid Well-Known Member
    casey
    Ny/nj
    11 dcsb sport
    2 inch front and rear. 32" stt pro's 30.5 inch bumper led light bar Volant cai
  17. Sep 12, 2016 at 7:03 AM
    Lilcarkid
    casey
    Ny/nj
    11 dcsb sport
    Rims and tires are unsprung weight. Weight In the cab as passengers or a load in the bed would effect the rear braking.
  18. Sep 12, 2016 at 7:15 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  19. Sep 14, 2016 at 11:09 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This thread is 5 years old.
    StarTrooper likes this.
