New lift few questions..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Jul 1, 2011.
  1. Jul 3, 2011 at 3:49 PM
    #61
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Damn cab mount that's next on list, did you just remove that plastic that covers the gap of the fender flares
  2. Jul 3, 2011 at 3:55 PM
    #62
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    I guess you shoulda gone with the pro comp lift ;)
  3. Jul 3, 2011 at 3:55 PM
    #63
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    And blacktacoma how much did you cut off of the cab mount? 1/4" or more?
  4. Jul 3, 2011 at 4:00 PM
    #64
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    I wonder if the reason I am rubbing more on driver side is because of taco lean. Seeing how the passenger side is higher this could be why my driver side is rubbing more because that side is lower. I might try a taco lean spacer and see if that helps
