New lift kit installed: New noise-what am I hearing???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Claims Rep., Jun 25, 2011.
  1. Jun 25, 2011 at 9:25 PM
    Claims Rep.
    Claims Rep. [OP] Member
    Huntsville, AL
    2006 Tacoma 4x4 Doublecab
    I have an '06 Tacoma Double Cab 4x4 with a 6 cyl. This Friday I installed a lift kit: Toytec front 3" spacers with 2" AAL in rear. I also installed a front differential drop kit. I did not replace the UCL's. Today I got the front end aligned. All numbers are within range except for the Caster, which is 1.0* on front left, and 0.8* on front right.
    Anyway, when I drive now my factory street tires sound like buckshot mudders on the highway. So, what is causing this noise, have I installed something wrong, and most importantly, is something about to tear up? As far as operation goes, I haven't seen or felt anything wrong. I do know this sound is coming from the front end. Anybody got any ideas?
    Thanks in advance,
    Derek
  2. Sep 27, 2011 at 5:01 PM
    geoandrew
    geoandrew Member
    George
    North Alabama
    2011 Tacoma 4x4
    3 " Lift Kit Tuff Country
    I just installed a 3" tuf country lift on my 2011 regular cab 4x4, same spacers as you. the rear differential sounds like a chicken bone in the garbage disposal @ 60 mph when you play the accelerator between powering and holding back. While powering a loud roar with noticeable vibration happens between 55-65 mph, all other speeds are quiet. Checked the fluid/u-joints all OK. Took it by dealership (only has 6000 miles) and described the problem. Will take back this Friday for test drive with mechanic and see what they say. It was doing this before the lift but not near as noticeable. Could be as simple as not putting proper LSD fluid in at factory. May be worse. Will see...
  3. Sep 27, 2011 at 8:40 PM
    SbRsH11
    SbRsH11 Member
    Virginia
    06 TRD Sport
    Are you sure that it's the tires? Did you shim the carrier bearing? When I lifted my '01, I didn't initially and I had a horrible vibration that sounded like that.... Shim kit and longer bolts fixer her right up!
  4. Sep 27, 2011 at 8:46 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    For any one who has put a lift kit on the front and gets vibrations afterwards, do this;
    Drive on strait road til you here noise. When noise is at it's loudest, turn 4wd switch to 4hi. If noise goes away, you have bad front diff bearing. This is the result of the lift kit. Been there done that, no longer have a lift kit. Do a search on this site on how to replace the bearing if your warranty has expired.
  5. Sep 27, 2011 at 8:58 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Not always a result of a lift kit, sorry. Bearing is easy to replace provided you have a bearing puller though. Also, differential drops bring the CV geometry back into nearly stock angle if you're only slightly lifted.
    You could have a bad bearing, and not necessarily the diff bearing, there are the wheel bearings too. It may have already been there and the lift is only making it sound worse. Your alignment is far from 'in spec' as well, until you get UCA's it will drive funny. Also, your tires will probably scallop.
    Nothing should be as loud as you are describing it though. You have to play with it a little. Telling us you have a loud noise in the front end really doesn't give us anything to go on. If you can isolate the sound to one side maybe? Symptoms like this would lead me to believe bearings are bad, however if its a hollow sound, from both sides, it is probably your tires, and either your previous alignment was NOT correct and your tires wore wrong, or your new alignment is not as good as you thought.
  6. Sep 27, 2011 at 9:08 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  7. Sep 27, 2011 at 9:13 PM
    brian
    Elizabeth City, NC
  8. Sep 27, 2011 at 9:24 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  9. Sep 27, 2011 at 10:15 PM
    brian
    Elizabeth City, NC
  10. Sep 28, 2011 at 2:39 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    subed. have the same problem after my lift and the mechanic swears it's a wheel bearing.
  11. Sep 29, 2011 at 12:37 AM
    brian
    Elizabeth City, NC
    Theres no doubt, if you have the symptoms and it goes away in 4WD, its the diff bearing... really nothing else it could be.
  12. Sep 29, 2011 at 1:40 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I got this on my 2011 V6 Prerunner, vibes at 55-60 mph (odometer reads 62, but I got 33" tires)
    I'm thinking its the angle of the driveshaft after lifting (Eibachs, spacers, AAL). To simply cut out the fact that its not the tire, I put it on cruise at the speed it vibes at, and dropped it into Neutral.... sound went away...
    I'm thinking of doind the carrier bearing drop and adding shims to see if theres a change
  13. Sep 29, 2011 at 4:32 PM
    Claims Rep.
    Huntsville, AL
    Lots of good comments here, and they are appreciated. What I ended up doing was buying longer bolts for the carrier bearing and added shims. This noticeably straightened out the drive shaft angle, plus (obviously) reduced the noise level.
  14. Sep 29, 2011 at 5:51 PM
    joelong0004
    joelong0004 Well-Known Member
    Joe
    Manteca, CA
    2011 Tacoma, TRD Off-Road
    - Rancho 2.75" quick lift with Skyjacker leaf packs - Rancho 9000xl adjustable shocks - 32" tires - New 16" wheels with "0" off-set - Borla ProXS exhaust - nfab nerd bars - Weather Tech floor mats - Wet Okole seat covers
    I had a 2008 Tacoma TRD Sport with a 3" lift. My center support bearing went out and I had to replace it. When I did, I had to replace the front u-joint as well. It was shredded inside and the needle bearings were dust. The u-joint was never greased from the factory. There was no evidence of any lubrication at all. The u-joint looked like it was ready to come apart from the wear. Metal on metal is "no bueno".
    Check your u-joints and lube them at the grease zert. You can also upgrade your center support bearing from the cheap OE one to a stronger more durable material.
    I just lifted my 2011 TRD Off-Road and the first thing I did was lube the u-joints.
    - Joe
  15. Sep 30, 2011 at 5:18 PM
    Claims Rep.
    Huntsville, AL
    Point well taken. That will be on the agenda tomorrow.
  16. Oct 2, 2011 at 5:56 PM
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    i have 2010 4x4 sport and installed 5100's with 885x's and 1/4" spacer up front and 2" aal, diff drop and only had take off shutter. no biggie, but then i upgraded to coilvers up front with tc uca and now i have ugly vibes at 55mph and above that are driving me bananas :mad: i ordered a cb drop kit from beefed taco and still no luck. at 50mph i switch to 4h and still have vibes. so ive run out of options and read all the threads on vibrations and dont know what to do now.
  17. Oct 3, 2011 at 12:38 PM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  18. Oct 3, 2011 at 12:48 PM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    What if your hearing growling/crunching in drivetrain, and chirping in the rear tires when she's ENGAGED in 4wd? I'm also having issues getting her back into 2H.
    01
    6" lift
    Think growl in coming from fwd left side...
  19. Oct 3, 2011 at 2:54 PM
    HB Taco
    Curt
