New Lift noise ?
Discussion in 'Suspension' started by Ravenfan, Apr 23, 2015.
  1. Apr 23, 2015 at 1:33 PM
    Ravenfan
    Ravenfan [OP] Well-Known Member
    Virginia
    15 TRD Sport DCLB
    5100 Bilsteins, 884x, 1 1/2inch Rear block, Toyo Open Country AT2 LT265/75/16 C
    I just had my new lift installed. 884 with 5100 and 1 1/2 rear block. I am getting a noise that is most prominent between 35 and 50. I don't know if it is a vibration or what. It is in and out every 1 to 2 seconds, WAA...WAA...WAA. Please do not laugh that is the best description I can give. Any ideas? I can not really tell where it is coming from either. Thanks for any help
  2. Apr 23, 2015 at 1:37 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Did you get an alignment yet?
  3. Apr 23, 2015 at 6:21 PM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
  4. Apr 23, 2015 at 10:51 PM
    kmcivor
    kmcivor Active Member
    KC
    Cle Elum, WA
    2007 AC TRD Off-Road
  5. Apr 24, 2015 at 8:18 AM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    kmcivor could you provide a bit more information that link is not working. Thanks
  6. Apr 24, 2015 at 12:40 PM
    kmcivor
    KC
    Cle Elum, WA
  7. Apr 24, 2015 at 12:53 PM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    Thanks I was reading that earlier this morning. I have reached out to my dealer to see their response. I am unable to do this work myself and really do not have any additional money to spend right now. That looks like an extensive repair.
  8. Apr 25, 2015 at 12:48 PM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    Ok it is looking like I either need to lower truck down or go with either a Camber Bearing drop or ECGS bushing. Any input or help would greatly be appreciated
  9. Apr 25, 2015 at 12:50 PM
    Flowin
    Acworth, Georgia
    I run 5100s 885x and 1.5" in the rear and don't have any noise? Does it go away when you put it in 4x4?
    No need to lower it...it's not that high :)
  10. Apr 25, 2015 at 2:29 PM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    Yes it does go away when put in 4WD.
  11. Apr 25, 2015 at 4:17 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Thats your needle bearing replace with ECGS bushing and you will be good to go...:D
  12. Apr 26, 2015 at 1:57 PM
    kmcivor
    KC
    Cle Elum, WA
    What she said. I had my local shop do mine and it cost me about $200. I think it's a pretty straight forward install I just didn't have the time to do it myself.
    I had been running mine for about a month before I replaced the bushing (probably 3,000miles) and the shop said that there were no signs of damage of any kind. If you don't have the cash right now you can probably wait a bit to do it. As long as the vibration isn't driving you nuts :annoyed: It drove me crazy!
  13. Apr 27, 2015 at 3:26 AM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    I was looking at the front of the truck yesterday and saw my front tires are like \ / if they did not do another alignment after going back and adding the top plate spacers is it possible this could be causing the noise?
  14. Apr 27, 2015 at 5:16 AM
    303tacoma
    Rebecca
    afer adding the spacers an alignment should have been done, but I think the source of the noise is the bearing, considering it goes away in 4WD
  15. Apr 27, 2015 at 5:22 AM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    X2 on the needle bearing.. if u can change a cv axle u can install the bushing. I had same vibe/sound and the bushing cleared it all up
  16. May 15, 2015 at 8:37 AM
    Ravenfan
    Virginia
    15 TRD Sport DCLB
    Just thought I would update anyone following this. I had the ECGS bushing installed this week and my problem is now gone. Thanks to the guys there for fixing Toyotas problem!!!
