New Lift...Not as high as planned!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by curtsmith17, Nov 25, 2011.
  1. Nov 25, 2011 at 11:15 AM
    curtsmith17
    curtsmith17 [OP] Active Member
    SMITTY
    ON
    09 4x4
    Bilies 5100 All Four Corners (O.85" in Front), Eibach/Toytech Springs, URD Short Shifter
    After a few weeks of research and going through every suspension thread I could find I decided on my new lift:
    Eibach w/ 5100 (0.85) Front (should give me 2.45")
    5100 Rear
    1.5 AAL for the rear (may not install)
    Before:
    After:
    It seems that I only gained 2" in the front!?! So as the truck sits now I won't need the AAL in the rear. This is a Canadian truck with 4 leafs in the back.
    I'm perfectly level :drunk:
  2. Nov 25, 2011 at 11:39 AM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    Did you take before and after measurements hub center to top of wheel well?
  3. Nov 25, 2011 at 1:20 PM
    curtsmith17
    SMITTY
    ON
    09 4x4
    Was expecting at least the 2.45" in the front but this will do....may have a 1.5" AAL for sale!?! Might add UCA's and spacers w/ the AAL???? We'll see how Santa is feeling next month!
    Center Hub to top of wheel well.
    RF Before: 20.5" After: 22.5"
    LF Before: 20.25 After 22.25"
    Rear is sitting at 22.5" both sides with the 5100's Center Hub - Top wheel well.
    I'm satisfied with the way it turned out...rides great....still needs an alignment. No pulling or vibes right now!
    The wheels on right now are my Winter Beaters!!!
  4. Nov 25, 2011 at 1:22 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Truck looks great
    :canada:
    :woot:
  5. Nov 25, 2011 at 1:25 PM
    TANK
    TANK Well-Known Member
    GTA CANADA
    2008 TACOMA 6SPD 4WD E-Locker
    885 on 5100, dakar leaf pack, N182, BFG AT, colour match grill, Weather tech, Marathon Super-hide seat covers, Leer 100R w/Yakima rack, ROLA basket, sleeping platform, tailgate theft mod, Plasti-dip badges, bed liner: TRD skid/rear bumper, ABC extinguisher
    I think it still looks good leveled. Like you said you can always lift it more in the future. Where did you order your eibach's from?
  6. Nov 25, 2011 at 2:01 PM
    curtsmith17
    SMITTY
    ON
    09 4x4
    Ended up ordering the springs and AAL from toytec...little expensive with the shipping but they were awesome to deal with and fast shipping. :woot:
  7. Nov 25, 2011 at 6:30 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    looks good!
  8. Nov 25, 2011 at 7:07 PM
    miagi
    miagi Member
    This is the lift I'm planning. How's the ride quality compared to stock?
  9. Nov 26, 2011 at 7:15 AM
    curtsmith17
    SMITTY
    ON
    09 4x4
    Ride is great...still waiting to get into the alignment shop, but it runs straight, no vibes/pulling. Hopefully stays that way after the alignment. I'm hoping to get away with the stock UCA's for now. We'll see!
  10. Nov 26, 2011 at 11:12 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    You should have no problems with alignment. Lifting only changed your camber so it shouldn't pull, it would only make your tires wear unevenly. Truck looks great though!
  11. Nov 26, 2011 at 11:14 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    it looks great the way it is man.
  12. Nov 26, 2011 at 11:15 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Go up on the 5100's and install your AAL. You'll push your entire truck up a little :)
    I mean, you have more notches on those 5100s and you already have the AAL!
  13. Nov 26, 2011 at 11:19 AM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    So Eibachs are ~1.5 inches taller than stock coils?
  14. Nov 26, 2011 at 11:21 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    They are not. They don't need to be 1.6" taller to lift the truck 1.6" because of the nature of the IFS. Think of a fulcrum under a see saw . If you raise it up an inch, the high end of the see saw will raise up more than 1 inch.
  15. Nov 26, 2011 at 11:25 AM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    If you dont mind me asking how much did they lift set your back?
  16. Nov 26, 2011 at 11:26 AM
    Airun
    Aaron
    Show Me State
    Gotcha! So are they taller at all? or stiffer for less sag?
  17. Nov 26, 2011 at 11:32 AM
    TexasTacoma37
    I'm not positive but I think they are both slightly longer and slightly stiffer. Both of which accomplish lift.
  18. Nov 26, 2011 at 12:35 PM
    curtsmith17
    SMITTY
    ON
    09 4x4
    Yes the Eibachs are stiffer and taller by about a coil i think.
    This is CND$ but Thats 4X Billies ($420), Eibach springs ($150), 1.5 AAL ($80). you could probably do this set up cheaper in the US. + $130 installation.
    Bought springs and AAL from Toytec
    Billies 5100 from Essex Dist in BC
    One way or the other us Canadians get jaked on higher prices in Canada for the same stuff or high shipping costs from the US. :confused:
  19. Nov 26, 2011 at 12:36 PM
    SCFirefighter
    Stephan
    Cary, NC
    Plus don't you guys have to pay a sales tax / VAT type deal on everything too?
    See, over here you don't get charged a sales tax if you order something online and the store doesn't have a physical retail location in your state. Amazon FTW for example :)
  20. Nov 26, 2011 at 2:54 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I gotcha thanks!
