New lift put on. Go bigger tires?
Discussion in 'Suspension' started by Tacoma Zach, May 17, 2014.
  1. May 17, 2014 at 6:30 PM
    Tacoma Zach
    Tacoma Zach [OP] New Member
    West Virginia
    11 Tacoma TRD
    3" leveling kit (Fat Bob's 3" front 1" back)
    I finally got my 3" suspension lift from fat bob's garage put on today!!!! I am very pleased with the way it turned out. Now my question to tacoma world is, what the pros/cons with upgrading tire size?
  2. May 17, 2014 at 6:31 PM
    Tacoma Zach
    West Virginia
    11 Tacoma TRD
    Currently have 265/75r16 on
  3. May 17, 2014 at 6:38 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
  4. May 17, 2014 at 6:42 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    What are you going to do with the truck? If you're going offroad a bunch then you might consider going up to 33s - for a little more ground clearance. This comes with some sacrifice though.
    For me, it was worth it. A little lower mpg and power loss wasn't that noticeable. Although my auto trans drops out of overdrive pretty easily.
  5. May 17, 2014 at 6:44 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    33s fill the wells nicely also.
  6. May 17, 2014 at 6:52 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    id do it... balances out the truck nicely with bigger tires
  7. May 17, 2014 at 7:56 PM
    Tacoma Zach
    West Virginia
    11 Tacoma TRD
    Would i need spacers on the front for 285/75s?
  8. May 17, 2014 at 11:01 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    If you want to keep your stock wheels, then you'll need a minimum of 1" spacers. Bottom line is that you don't want more than 4.5" of back spacing on the wheels.
