New Lift Questions
Discussion in 'Suspension' started by =JSG=, Dec 23, 2011.
  1. Dec 23, 2011 at 10:05 PM
    =JSG=
    =JSG= [OP] Well-Known Member
    Canada
    2017 DC TRD OR 4x4 SB
    Morimoto 2 Stroke lows, Baja designs Squadron-R Sport as fogs, Method NVs
    What is installed:
    - Bilstein 5100 front/rear
    - Eibach Coils
    - 2" Toytec AAL
    - Front Diff drop
    After the lift:
    Trucks rides great in the city but on the highway at 70+ MPH I notice my steering wheel tugs right and left.
    Shop said I am at the maximum setting even though I told them not to exceed 2.5" because I want to keep my stock UCAs. I told them about the issue they said it sounds like wheel balance is off. I am not sure how high I am but it looks like 3"
    Question:
    - Is this because of my stock UCAs? or is it just my wheel balance? Alignment shop did not put weights on the outside ( Wheel: Pro Comp 7089)
    Truck with the lift before I get bigger tires:
  2. Dec 23, 2011 at 10:15 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Did the shop use the highest perch setting on the 5100s with the Eibach coils? That will give you excessive lift. Take a photo so we can see how many snap ring grooves are showing above the perch.
    Ask your alignment shop for the result sheet and see how much caster you have. If it's near zero, then UCAs are the answer to get more caster.
  3. Dec 23, 2011 at 10:16 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    :confused:
    Can you post a copy of your alignment report ?
    Your pic looks like you're over 3" in the front.
    Might want to check those half shaft (CV) angles, too.
  4. Dec 23, 2011 at 10:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    As above , your caster is probably maxxed out on your stock UCA's
  5. Dec 23, 2011 at 10:27 PM
    =JSG=
    Canada
    Pictures have been updated above
  6. Dec 23, 2011 at 10:42 PM
    jflan
    Vancouver, WA
    Looks like you're at the highest setting on the Bilstein.
    The lowest (0.0) or second (.85) setting is most commonly done with the Eibachs.
    Can't see your halfshafts (CV's).
    1. You're way high for this type of lift
    2. I'll bet your caster number is way low
    3. You might have to go to aftermarket UCA's
    4. You might also have to find an alignment shop that is familiar with lifted vehicles
    5. Caster needs to be between 2.4 and 3.1
  7. Dec 23, 2011 at 10:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The Eibachs by themselves usually provide 3" & I see your not set at 0' as you should be, 5100's are always set at 0' w/Eibachs for 1st @ 2nd gens.
    lower your ride hight & live happy forever.....:cool:
  8. Dec 23, 2011 at 10:57 PM
    USCoastGuard12
    USCoastGuard12 Well-Known Member
    Conner
    Beaumont,TX
    2007 Tacoma 4x4
    Black headlight, taillights, and center rear light. Custom grill, K&N intake,Revtek 3' lift,devil horn emblem,ballistic jesters
    maybe balance the tires.So it doesnt tug
  9. Dec 23, 2011 at 10:58 PM
    =JSG=
    Canada
    Alright, Im gon go tell the shop to fix it for free. Is it safe to drive? Also how does the CV look?
  10. Dec 23, 2011 at 11:02 PM
    jflan
    Vancouver, WA
    Keep a close eye on them if they set up Eibachs and Bilsteins like this.
    Can't see enough in the pic, plus they will improve once they set you up correctly.
  11. Dec 24, 2011 at 12:09 AM
    =JSG=
    Canada
    Thanks, jflan. Is it safe to drive this truck on the highway?
  12. Dec 24, 2011 at 5:57 AM
    KenLyns
    Belly of the Beast
    The spring perch is on the 2nd highest setting, which provides 1.75" lift on its own with stock springs, according to Bilstein's instructions:
    http://cart.bilsteinus.com/pdfs/E4-WM5-Y323A00.pdf
    The Eibachs are sized for 1.6" lift on their own, according to Toytec's page:
    http://www.toyteclifts.com/index.ph...tegory_id=115&option=com_virtuemart&Itemid=72
    Stack these together and you are at about 3.4", which is too high, as evidenced by the severe (and destructive) angle at the inboard CV boots.
    Go back to the shop and get them to move the spring perch to the 3rd highest setting, which gives 0.85" lift. 0.85" + 1.6" = about 2.5". When they do the alignment, ask them to maximize caster, even if it results in slight positive camber.
  13. Dec 24, 2011 at 7:52 AM
    =JSG=
    Canada
    Thanks, will I need new UCAs even at 2.5"?
  14. Dec 24, 2011 at 8:18 AM
    KenLyns
    Belly of the Beast
    The stock UCAs will be a compromise at 2.5" - the shop can adjust the LCA cams to maximize caster, but they won't reach the desirable 3 deg., and in the process will end up with some positive camber, which is not good for handling. In the end it depends on what you can live with. Steering feel won't be as good as stock height, but an improvement over what you have now.
    If you decide to go for UCAs, go to a better shop. If they can butcher a simple strut lift like this, I wouldn't trust them with UCAs. The uniball UCAs require more care at installation than stock UCAs, and even Toyota dealers can't always do them correctly.
  15. Dec 24, 2011 at 9:23 AM
    OZ-T
    Peter North
    British Columbia
    That's on a 1st gen .
    They provide 1.6" on the 2nd gens
    on the 2nd gens the billies can be at .85 , lots running that set up .
  16. Dec 24, 2011 at 9:38 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You are right great OZ, I keep forgetting about the difference's with plastic gens. :D:D
  17. Dec 24, 2011 at 9:51 AM
    KenLyns
    Belly of the Beast
    ^Plastic doesn't rust; those of us outside the desert states can appreciate that. :D
  18. Dec 24, 2011 at 1:09 PM
    =JSG=
    Canada
    Anyone have a decent pair of UCAs? Someone recommend me good shop in Bellingham WA.
  19. Dec 24, 2011 at 1:12 PM
    OZ-T
    Peter North
    British Columbia
    I went with LR UCA's because I wanted a sealed ball joint for my winter driving conditions .
  20. Dec 24, 2011 at 1:18 PM
    =JSG=
    Canada
    Sounds good thanks, I will update the photos when I get the shocks installed correctly. Any idea how much it costs to get UCAs installed and I'm guessing will need alignment again.
