New lift/tires - UCA rub
Discussion in 'Suspension' started by outdeh, May 13, 2013.
  1. May 13, 2013 at 5:39 PM
    outdeh
    outdeh [OP] Active Member
    Durango, CO
    2016 TRD Offroad 4x4
    Alright, so here's my situation (this is long-winded, I apologize!). I just installed a new suspension/lift on my 2010 Tacoma 4x4. On the front I went with Bilstein 5100s with OME 885 coils, and on the rear the OME Dakar leaf set and OME Nitrocharger Sport shocks. Ended up being about a 3 inch lift front and rear.
    I took the truck to Discount Tire and very clearly told the sales guy that I wanted the BFG All-Terrain T/A KO tires, biggest I could go WITHOUT getting any rub. We agreed they'd put 'em on and test them for rub before I walked out. I made the mistake of going out for breakfast while they did it instead of demanding to have it tested before my own eyes. After being assured they were tested, wheels turned all the way, and no problems...sure enough, as I'm reversing into my parking place at home, I feel/hear some nice rub.
    The tires aren't rubbing anywhere on the well or fender, they're rubbing on the control arm. Luckily, it only happens when I turn the wheel pretty sharp, mostly when reversing out of parking spots. I took it to my mechanic, and after checking it out, he said it's not really a problem, that it won't hurt anything. Even if that's the case, it's not something I want to live with forever.
    The new tires are 285/75R/16, I love the size, don't want to downgrade now that I have them. So, my goal is to find a way to eliminate the rub. One solution I've considered is getting new wheels with an offset to provide a bigger gap between the tire and UCA. I've been thinking about getting new wheels anyway, so I'm not against it. What do y'all think about this as a solution? Any problems with offset? Any other ideas?
    Since I'm a newbie on here, here are a few pics of the truck with new lift. Thanks for any help!
  2. May 13, 2013 at 5:42 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get wheel spacers
  3. May 13, 2013 at 5:43 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
  4. May 13, 2013 at 5:45 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Im running the same tires, wheels, and front lift. Get some wheels spacers for sure
  5. May 13, 2013 at 5:54 PM
    outdeh
    Durango, CO
    Thanks for the quick replies. That'd be a cheaper solution than new wheels! Any recommendation on spacer size?
  6. May 13, 2013 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
  7. May 13, 2013 at 5:56 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Ive got spidertrax 1.25" all around. You only really need one pair of them though
  8. May 13, 2013 at 5:56 PM
    OZ-T
    Peter North
    British Columbia
    That would look stupid , no ?
  9. May 13, 2013 at 6:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    That's a 33" tire. If you put on a 1" or 1.25" wheel spacer, the tire will pivot on a larger scrub radius and rub the fenderwell plastic.
    Better to get wheels with 15mm offset. This will space out the tires by about 0.67". This results in less rubbing on the fenderwell. An example is the FJ 6-spoke wheel:
    http://trdparts4u.toyotaofdallas.com/Scripts/prodView.asp?idproduct=331915
  10. May 13, 2013 at 6:05 PM
    OZ-T
    Peter North
    British Columbia
    Good point
    could also consider the Bora spacers
    ( select 6 lug in the drop down menu )
    http://www.motorsport-tech.com/4DCGI/special/truck/clickedlug_s
  11. May 13, 2013 at 6:48 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    That wouldn't look stupid at all...? You wouldn't even notice. Ive seen members do it
  12. May 13, 2013 at 6:53 PM
    outdeh
    Durango, CO
  13. May 13, 2013 at 6:53 PM
    teneighty
    Yes
  14. May 13, 2013 at 6:57 PM
    KenLyns
    Belly of the Beast
    Bora spacers can be ordered in 0.75" thick, so it's almost as good as using 15 mm offset wheels.
    Spacers are cheaper than new wheels of course, but all other precautions apply. For example, you can't use impact guns on them.
  15. May 13, 2013 at 7:03 PM
    OZ-T
    Peter North
    British Columbia
    I think I would notice if the front wheels stuck out 1 1/4" more than the rears
  16. May 13, 2013 at 7:18 PM
    boopie
    boopie 05trdoffroad
    Ramon
    San Diego
    05trdoffroad
    Toytec/Eibach Bilstein set at .85, URD TCAI , TRD catback exhaust,1.5" AAL
    Here is the only solution. Trade it with my BFG AT tires. 265/75r16 same wheels. Guaranteed you won't rub.
  17. May 13, 2013 at 8:25 PM
    outdeh
    Durango, CO
    Thanks for all the input fellas. Much as I'd like to get new wheels, my wallet is pretty thin after the lift and new tires. I think I'll go with the Bora 0.75" spacers.
  18. May 13, 2013 at 9:07 PM
    KenLyns
    Belly of the Beast
    You may well have to trim the fenderwell plastic with 0.75" spacers, though not as much as you would have with 1.25" spacers.
  19. May 13, 2013 at 9:10 PM
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    these will give your front a really nice stance
  20. May 13, 2013 at 9:32 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Oh you sly dog
