New lift
Discussion in 'Suspension' started by bamaboy0323, Jan 21, 2010.
  1. Jan 21, 2010 at 2:07 PM
    bamaboy0323
    bamaboy0323 [OP] Member
    Just got my lift on Monday. I just noticed today that it looks like my drivers side front sits lower than the passenger side front. I have been reading about the "lean" issue with tacomas. I am running the 3" OME with the Nitro shocks, OME881 coils, and the add a leaf and extended shocks in the back. I thought i read somewhere that the lift i have would take care of that issue. Can someone please provide insight for me on the issue. I know 3/8's of an inch isn't that much of a difference but it is noticeable to me. Thanks guys.
  2. Jan 21, 2010 at 3:58 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    sounds like u need the top plate spacer.
  3. Jan 21, 2010 at 4:17 PM
    bamaboy0323
    i think the lift came with a 1\4 inch top plate spacer for the full 3 inch lift. Will another 1/4 inch top plate spacer work on top of that.
  4. Jan 21, 2010 at 4:25 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    not sure on stacking 1/4 spacer.maybe someone will chime in and help you.good luck
  5. Jan 21, 2010 at 5:33 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    post up a pic so people can see what you got on there and then they can help you more effectily
  6. Jan 21, 2010 at 5:38 PM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
  7. Jan 22, 2010 at 8:12 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    NO!
    At this point, you would want to use only the OME 5mm trim packers to address your taco lean.
