New light bar is not turning on, ...help?
Discussion in 'Lighting' started by cacocker, Nov 10, 2024.
  1. Nov 10, 2024 at 10:06 AM
    cacocker
    cacocker [OP] Occasional Smartass
    Corey
    Seattle
    2017 TRD OR DCLB MGM
    Mods: https://bit.ly/34WhzsW
    I recently installed a 40" 540W light bar by Offroadtown, purchased on Amazon.
    Since I have an Auxbeam AR-800, I figured I didn't need the included wiring harness. So I wired the bar direct to the Auxbeam (which is working for other items wired in to it) by removing the wiring harness connection from the bar and connecting the red and black directly.
    I've tested the power supply using a light up probe/tester. I'm getting power all the way up to the bar, indicated by the probe, including past the butt splices connecting the original cable to the wiring I used to get to the Auxbeam.
    The bar is hooked up to the Auxbeam using a 40A fuse, which is what came in the box.
    The one thing I didn't check before I started cutting stuff apart was whether or not it actually worked. Yeah, hindsight is 20/20. I've included some photos, knows if they're helpful or not.
    Any help those of you more experienced than I can offer would be appreciated.
  2. Nov 10, 2024 at 10:19 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Big question…the Ar800, from the product photos the max circuit is a 30a but you are running 40?
    If that is the case perhaps some safety mechanism on the switch panel is refusing to run that circuit as it’s sensing too much current. My only guess.
    Take the wire leads for the bar and run directly to your battery as a test. If it turns on then it’s the auxbeam panel.
    cacocker[OP] likes this.
  3. Nov 10, 2024 at 1:27 PM
    cacocker
    Corey
    Seattle
    Your first question, I was incorrect about the 40a fuse. Its a 20a inline on the wiring harness.
    First problem, I had it plugged in to the wrong slot on the bus. It was in a 10a fuse slot, and the fuse had blown. So I switched it to a 20a slot (and replaced the 10A fuse). Tested that, fuse intact, no light.
    Next test, disconnected the light bar from the extension I wired to the panel with. Just the red and black straight from the light bar, nothing. (confirmed the battery is charged)
    Looks like I'll be returning it. Any suggestions on 40" bars?
  4. Nov 10, 2024 at 1:35 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Diode Dynamics sells 42" bars. Id look at Hotshot Offroad as it's ran by a member on here.
  5. Nov 10, 2024 at 3:07 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    You're going to return it after you cut the harness?! Did it work before you cut the harness? Where did you cut the harness? What does your setup look like now?
    Item description says 540W, which is 45A. I don't see any other power claims in the listing.
  6. Nov 11, 2024 at 7:17 PM
    cacocker
    Corey
    Seattle
    Its not a return, its a warranty claim.
    The harness was not cut, you can check in the photo. The male end of the coupler was removed on the bar wire to expose the +/- wires.
    Manufacturer sent a 20a fuse and it hasn't blown yet.
  7. Nov 11, 2024 at 7:37 PM
    OldSchlPunk
    Rich
    East Central Wisco
    You said nothing of a warranty. I see nothing in your pictures that show a plug opened up to expose wires. That wiring harness is completely useless to you if you're hooking up to an Auxbeam.
    I have my light bar run directly to my Auxbeam controller/grounded right next to the Auxbeam. I cut the plug off of the light bar and ran wires from it to the controller. Before I cut the plug, I ran test wires from my battery to the plug to verify the light bar worked.
    It's really hard to guess what your problem is or how you're trying to connect the light bar off of the pictures you provided.
    bagleboy likes this.
  8. Nov 11, 2024 at 9:46 PM
    cacocker
    Corey
    Seattle
    I'll go with the people who are actually offering suggestions rather than looking for points to criticize. But thank you anyway.
  9. Nov 12, 2024 at 6:37 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Tried to help...whatever...good luck.
