New lighting
Discussion in 'Lighting' started by laemmons, Oct 14, 2011.
  1. Oct 14, 2011 at 6:49 PM
    laemmons
    laemmons [OP] Active Member
    North Carolina
    TRD Sport 4x4
    My new truck!
    HID headlights and superwhite fog lights
    LED interior lights. They make a big difference!
    These are scanner LEDs that turn on when my security system is armed.
    The high beams are regular halogen bulbs but they really suck so next week I'm getting a black billet grille put in with the KC off road lights mounted behind them. I'm also getting it wired so that my HID lights will stay on when I turn the high beams on so it'll be even that much brighter. Then when I just need low beams, I'll flick the stock high/low beam switch to turn off the off road lights.
  2. Oct 14, 2011 at 6:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Very nice.
  3. Oct 14, 2011 at 6:59 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
    Bright as hell...and its still daytime out lol!
  4. Oct 19, 2011 at 2:45 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    attracting a lot of attention to your truck.curious people do weird things.
  5. Oct 19, 2011 at 8:04 AM
    laemmons
    North Carolina
    TRD Sport 4x4
    What do u mean by that? :confused:
  6. Oct 19, 2011 at 8:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How are your high beams regular halogens, did you replace the head light housing with a dual bulb set-up?? :confused:
    If you used a plug and play HID kit for your stock headlights there's no way you have HID low beams and halogen high beams...
  7. Oct 19, 2011 at 8:19 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Those blue "scanner" lights, though they look cool, actually will draw quite a bit of attention... Someone walking by will automatically be attracted to a moving blue light. At the very least they'll look at it. As much as you think it is more of a deterrent and making sure people know that your security system is armed, I agree with above and say that they likely attract more attention than you want. Many criminals do not care at all whether or not your security system is active. If they want to break in, they will. Just trying to look out for you...
    With that out of the way, welcome to TW from Montana! :wave:
  8. Oct 20, 2011 at 10:27 AM
    laemmons
    North Carolina
    TRD Sport 4x4
    As far as the scanner lights for my security system, I had a similar setup on a 2002 Mustang GT that I use to have. Somebody broke into my car before the security system was put on, but never afterwards. But I get what you're saying about drawing attention. Just figured a thief would go for an easier target. Plus my key fob remote will beep if the alarm is triggered.
    The HID setup on my truck is a two bulb setup. There is a halogen bulb built onto the HID bulb. I had never seen anything like that before. The installer said it was made for the purpose of passing inspection or something. But the built in halogen bulb is weak and so I don't use it. That's why I'm getting it wired so when I use the stock hi/low beam switch, my HIDs will stay on and just the KC off road lights will come on and off. My truck is actually at the installer right now getting the grill and off road lights put in. Will post pictures afterwards.
  9. Oct 20, 2011 at 10:35 AM
    memario1214
    Colton
    Missoula, MT
    I demand pictures!!!
  10. Oct 20, 2011 at 1:01 PM
    laemmons
    North Carolina
    TRD Sport 4x4
    Just got it finished. Still daylight so can't tell how well they work but here are a couple of pics. And got it wired so that the HIDs stay on with high beams. But I definitely like the look.
  11. Oct 20, 2011 at 4:21 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    wat brand HID's? and r they 6000k? they look hot as hell!
  12. Oct 20, 2011 at 4:29 PM
    tcoma12
    tcoma12 New Member
    Dru
    Huntington Beach
    Magnetic grey, SR5,4x4, Long Bed
    Camburg coil over with controle arm with a 3 inch lift. Fuel rims and mud tires
    How and where did you get the scanner led lights and how easy is it to install it looks bad ass.
  13. Oct 20, 2011 at 5:10 PM
    memario1214
    Colton
    Missoula, MT
    I need pics of these super bulbs... I've honestly never even heard of it
  14. Oct 20, 2011 at 9:16 PM
    laemmons
    North Carolina
    TRD Sport 4x4
    This is very similar to the bulb I used. But like I said the halogen part is weak.
    They are Digital-Technologie 6000k HIDs. As far as the scanner LEDs go there are a bunch of different brands, colors, types etc. They are not expensive either. The alarm system already has an output for a little LED just like you see on any other alarm system. They ran a little extra wire and tied the scanners into it and viola!
  15. Oct 20, 2011 at 9:34 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Don't be surprised if the law has something to say about your blue scanner lights. Here, any blue/red lights, on ones' vehicle (that's not a emergency vehicle) moving or otherwise, is a huge no-no.
  16. Oct 20, 2011 at 11:19 PM
    laemmons
    North Carolina
    TRD Sport 4x4
    A car can have them on as long as its not a full on strobe and as long as the vehicle isn't moving. They can't be turned on while the truck is moving because they turn off when the alarm is off.
  17. Oct 21, 2011 at 12:50 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    ....I dig
    :thumpsup: OP
  18. Oct 21, 2011 at 1:11 AM
    t4daddy
    North Alabama
    I'm not sure how the law is written, I've just seen local 5-0 harrass some guys in a parking lot, and them not even in the vehicle. The other time was a motorcycle all decked out with LEDs. It does seem as the bikes were flashing IIRC.
  19. Oct 21, 2011 at 3:10 AM
    memario1214
    Colton
    Missoula, MT
    Holy Shits, never even heard of these guys... :thumbsup: for getting me a pic and making me a believer.
  20. Oct 21, 2011 at 5:44 AM
    Pugga
    Massachusetts
    Whoa... :eek:
    That's a crazy looking bulb!
