New Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by branden, Jun 2, 2009.
  1. Jun 2, 2009 at 7:56 AM
    branden
    branden [OP] Member
    salt lake city
    03 Xtra cab SR5
    So i just put some HID's in... Man is it nice to have..:)
    I'll take some pictures tonight, I did have to dis able my day time running lights in order to have everything work properly. To do so you have to go under the driver dash and you'll find a black box that says day time running light control. Unplug it and turn the plug clock wise and you'll see a white wire with a neon green strip. once you find it you have the option to cut it or
    pull the wire out of the socket that way you can put it back in if you were to sell your truck or something
    If anyone is wanting some i can get the hi/lo H4 for about 170 a set. 6000k and 8000k
  2. Jun 2, 2009 at 7:55 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    thanks for the tip i just ordered some 8000k hids and i couldnt figure out how to diable my dtrl.
  3. Jun 2, 2009 at 8:42 PM
    gunn
    gunn Member
    Durango, CO
    04 xcab SR5 4x4 5spd
    You replaced your headlights? Do you worry that the low beam is too bright for oncoming traffic?
    Thanks
  4. Jun 2, 2009 at 8:57 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    I love Bi-Xenons! The only part on my Mazda that I will actually miss!
  5. Jun 3, 2009 at 9:00 AM
    branden
    branden [OP] Member
    salt lake city
    03 Xtra cab SR5
    No the BI lights have a cut off point that works the same as the stock head lights. Other wise you have to have projectors.
  6. Jun 3, 2009 at 9:02 AM
    branden
    branden [OP] Member
    salt lake city
    03 Xtra cab SR5
    yea My old car had HID's and ever since then i can't go with out... LOL:)
  7. Jun 3, 2009 at 1:57 PM
    trailinTaco
    Bel Air, MD
    im wondering did the same thing happen to you? if you dont disable the dtrl only one light will work unless you turn the lights on.
  8. Jun 3, 2009 at 2:06 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I just installed Bi xenon HID's on mine and fog lights too. My DTRL work fine. If you had to disconnect yours I think you may have done something wrong.
  9. Jun 3, 2009 at 2:17 PM
    branden
    branden [OP] Member
    salt lake city
    03 Xtra cab SR5
    Its not that i had to disconnect my dtrl i just prefer not having them so i thought i would share the how to.. Were did you install your Fogs at? I'm undecided on were i want to put mine.
    Thanks
  10. Jun 4, 2009 at 1:48 PM
    trailinTaco
    Bel Air, MD
    do you know where the body ECU or the dtrl relay is?
  11. Jun 5, 2009 at 11:55 AM
    branden
    branden [OP] Member
    salt lake city
    03 Xtra cab SR5
    Body ECU? No i don't
    The Relay is under the driver side Dash above the gas peddle. Little black box
  12. Jun 5, 2009 at 2:40 PM
    trailinTaco
    Bel Air, MD
    thanks i got it. it was a grey box on mine.
