New LR UCA SPC bushing started squeaking after only a few miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alapai1, Sep 30, 2013.
  1. Sep 30, 2013 at 1:49 PM
    Alapai1
    Alapai1 [OP] Well-Known Member
    Kory
    Mobile, AL
    2011 DBLCAB Taco TRD Sport 4x4 lifted
    Toytec Ultimate Lift kit with Bilstein Adjustable coilovers
    i literaly just finished installing my new spec ride LR UCA bushings on my tacoma and the squeak disapeared for all of a couple miles then returned just as bad as it was before with the old bushings. anyone have an idea why this is happening?
  2. Sep 30, 2013 at 1:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe that's not what was squeaking. ?
  3. Sep 30, 2013 at 2:00 PM
    Alapai1
    Kory
    Mobile, AL
    it definatly is. i had someone shake the truck while i put my head in the wheel well. could it be because i tourqed the nut while the truck was in the on the lift?
  4. Sep 30, 2013 at 2:03 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yes, this was going to be my question. You need to have it on the ground before torqueing. You may even want to drive it a couple hundred miles, loosen and let sit, then torque again.
  5. Sep 30, 2013 at 2:04 PM
    Alapai1
    Kory
    Mobile, AL
    when i loosen them to re-tq do i need to jack up the front or can i do it all while the truck is on the ground?
  6. Sep 30, 2013 at 2:13 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    No need to jack it back up.
    Since you have already driven it, it has probably settled a little. I would just loosen the bolts and bounce it some, let it sit for a half hour (grab a beer), bounce it again and torque it up.
    Do they give you a silicone grease for these? I have used silicone bushings on my old Celica, and they come with grease.
  7. Sep 30, 2013 at 2:27 PM
    Alapai1
    Kory
    Mobile, AL
    i have some silicone aerosole can grease. im gonna drive it for a day or two then do the re-tq. thanks. ill let you know if the squeak goes away
  8. Sep 30, 2013 at 2:34 PM
    Alapai1
    Kory
    Mobile, AL
    how loose should i go with bolts. one turn, more or less?
  9. Sep 30, 2013 at 3:06 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Is it possible to loosen it enough so it no longer squeaks?
  10. Sep 30, 2013 at 3:09 PM
    OZ-T
    Peter North
    British Columbia
    Like under-torque them ?
  11. Sep 30, 2013 at 4:08 PM
    Alapai1
    Kory
    Mobile, AL
    i will attemp this when i get the time again and keep you informed
  12. Sep 30, 2013 at 4:41 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I don't have these bushings, so I am just speaking from general experience with rubber suspension bushings (my old Celica has a 4-link rear suspension and panhard rod, 10 bushings in all, with a specific procedure for torqueing them down).
    When you tighten the bolts with the vehicle lifted, when you drop the vehicle the suspension compresses and the bushings can twist if there is too much pressure on them. They can then resist twisting even more and slip some when you hit bumps or compress the suspension more, creating the squeak.
    You just need to loosen them up to where there is no bolt presure on them, bounce the truck to get them to (hopefully) settle in, and then retorque to spec. Do NOT drive it with the bolt loose.
    I still think you should check other potential sources of the squeak. Noises can be tricky to pinpoint, stuff echoes around.
  13. Sep 30, 2013 at 4:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    MOLY GREASE
    Can torque spec rides without putting weight, they pivot freely.
    Did you grease the outsides of the bushings where they contact the washers, per the directions? Did you grease the inside where the sleeve rides?
  14. Sep 30, 2013 at 4:49 PM
    OZ-T
    Peter North
    British Columbia
    He said he didn't in the other thread
  15. Sep 30, 2013 at 4:50 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Mine did the same. I drove about 500 miles then the uniball started to squeak. I cleaned them, put teflon lube, and now they are fine 1K miles later.
  16. Sep 30, 2013 at 5:47 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    I have TC UCA's and they also squeak. I spray them with lithium grease a couple times a month and they still squeak. that's the one thing that annoys me about lifting the truck. oh well, I just turn up the radio to drown out the squeaking.
  17. Sep 30, 2013 at 6:25 PM
    OZ-T
    Peter North
    British Columbia
    LR UCA's don't have uniballs
  18. Sep 30, 2013 at 10:18 PM
    penguins_cc
    Will
    Bellevue, WA
    Yeah sorry :) I meant loosen them with the truck resting on its weight and then re-torque them.
  19. Oct 1, 2013 at 5:16 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    It doesn't matter, per the instructions.
  20. Oct 1, 2013 at 6:51 AM
    Marcitron88
    Marcitron88 Active Member
    The Great White North
    2013 MGM DCLB
    I thought my LR UCA bushings were squeaking as well...Had someone rock the truck and I stuck my head in the wheel well. I was positive that was the problem. Turns out it was the hood latch mechanism, Greased up the latch mechanism and BAM! Squeak is gone... :taco:
