New LSD or Locker Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rcfreak201, Dec 2, 2011.
  1. Dec 2, 2011 at 3:57 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  2. Dec 2, 2011 at 4:07 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Either get a new LSD or get an ARB. Its awesome having a locker man, I love it. Plus with the ARB youd have on board air.. But you gotta shell out the extra cash to get the compressor. And don't even think about going non-selectable, you would regret it when you go in snow or a wet area. And Detroit lockers suck. So arb or LSD
  3. Dec 2, 2011 at 4:59 PM
    johnw
    john
    orlando florida
    It's an auburn afrermarket limited slip.
  4. Dec 2, 2011 at 5:55 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Lol this whole thread gives me a headache :D
    Ok lets clear things here.
    1. If you planning to replace factory LSD then you need locker that also is a carrier. Hence no Powetrax, which also means whatever you get will cost you in gear setup. Rebuilding factory LSD costs only the clutchpacks or only shims if wear is minimal. There is no gear settings involved you just take a part and put it together the same way. So you can do it in your own garage with friends over the beer.
    2.
    Its not true.
    Truetrac is almost a open diff. Factory LSD is as close to locker as possible with out being actual locker.
    Here is what Truetrac does when one wheel gets in the air
    http://www.youtube.com/watch?v=Z94AvtCEIdc
    Factory LSD has preload that will pull you even with one wheel in the air (as long as it is not broken of course)
    3. Locker is best traction device unless you are not into hard of camber things.
    4. Truetrac is best for street racing and I would think high speed desert race type things, however if you slow down and send gets too deep you will get stuck
    5. Factory LSD is in between locker and Truetrac.
    Sounds like first thing you need to do is to figure out what do you want your truck to do.
    If you decide you are more into offroading then locker is good replecement, if you are more into street or desert runs then Truetrac. However if you are both I would look at rebuilding factory LSD
  5. Dec 2, 2011 at 9:46 PM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    Yukon makes the zip lock that is simular to the ARB and is cheaper
  6. Dec 2, 2011 at 10:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    watch this ARB video testing the Yukon locker and destroyin it...you'll never consider anything else besides the ARB:D
    http://www.youtube.com/watch?v=dyzyAVPTM8c
  7. Dec 3, 2011 at 2:51 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    this is rubbish. Do you have or have you ever had a TruTrac installed in your truck. TruTrac is great and blows the factory (brakes and engine) LSD away. Also what kind of bullshit video is that- all it shows is that the guy driving doesnt know WTF he's doing)
    The OP doesnt have the funds for ARB (being the best solution ) and is using his truck as a DD ,making a non-selectable Locker out of the question. Using the trutrac in conjuction with the oem trac control (brakes) is pretty damn good. If you are doing alot of desert (higher speeds) you can hold the track button for 5 seconds and just use the trutrac
  8. Dec 3, 2011 at 2:59 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    great video. ARB is and always will be the way to go for a full locker!!!!!
  9. Dec 3, 2011 at 3:07 AM
    Tookie
    Tookie Well-Known Member
    Port Vincent, LA
    2009 DC TRD Sport
    Are the clutches in the LSD not replaceable?
  10. Dec 3, 2011 at 4:04 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    OP if you decide that you want to stay with the original setup for your truck I will sell you my oem setup (only 5k miles on it).
  11. Dec 3, 2011 at 8:23 AM
    MonkeyProof
    SoCal- SGV
    4wp price matches..its the only thing they are good for. So if you shop around find a cheaper price elsewhere and show it to 4wp they will price match it.
  12. Dec 3, 2011 at 8:26 AM
    BlueT
    NorthEast
    Talking about rubbish. Op has 06 so no traction control. Second you want to sell him your open diff ? Your truck is 11 so you never had mechanical L s d. I am not telling Op what to buy, I am telling him to think before he spends money. Sounds like he is going with Truetrac and he won't be disappointed unless he finds himself offroading in some heavier things. You have traction control and that is what is making trutrac work in heavy offroading.
  13. Dec 3, 2011 at 8:48 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Rubbish. Traction control was an optional package in 2006.
  14. Dec 3, 2011 at 8:54 AM
    GP3
    California
    4X4 TRD Off Road
  15. Dec 3, 2011 at 9:35 AM
    #35
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    you make a good point. I forgot that 06's had a diffenent system
  16. Dec 15, 2011 at 1:49 AM
    #36
    Nick701
    Nick701 Well-Known Member
    17 TRD OR DC 4X4
    Good info, posting here for future reference
  17. Jan 27, 2013 at 10:41 AM
    #37
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    bringing this one from the dead... Rcfreak you ever get that tru trac? I had a detroit locker in the last jeep that was a DD.. i wheeled it a lot so it was worth it but a pain on the street. I want a detroit tru trac for my taco... the most aggressive limited slip on the market with good road manors still. also you can apply a little brake and it'll lock up like a locker.
    any personal experience with a taco with detroit tru trac?? mine's a TRD sport with auto. have traction control,ABS,auto lsd (not mechanical).
