New manual Tacoma shift issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kpla51, Sep 17, 2014.
  1. Sep 17, 2014 at 3:41 AM
    kpla51
    kpla51 [OP] Well-Known Member
    Fort Campbell
    So I bought a 2015 ac Tacoma with a manual transmission. Now going from first to second it feels rough in the shifter. In all the other gears it just seems to drop in but first to second feels different. Is this normal? My 03 jeep did the same thing but figured it was because it was older. This truck only has 500 miles.
  2. Sep 17, 2014 at 4:00 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    If you feel like there is a problem, just take it to the dealer and have them check it out. That way it can be on record that you brought it in for this problem.
  3. Sep 17, 2014 at 4:12 AM
    gearcruncher
    Canadain bumper technician
  4. Sep 17, 2014 at 4:14 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    +1 on going to the dealer to record the issue.
    These trucks shift better with Redline MT-90 gear oil, and first to second is one of the areas where RL MT-90 leads to smoother shifting. Do a TW search and read the many posts about it. Your truck is too new for this at 500 miles, but since you are sensitive to the feel of the manual transmission you will want to know about MT-90 for use in your truck later.
  5. Sep 17, 2014 at 6:33 AM
    kpla51
    Fort Campbell
    It's not so much as being sensitive to the feel of a manual. I don't mind it it just seems odd. If I double clutch it the problem seems to go away
  6. Sep 17, 2014 at 8:55 AM
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    go to the dealer and get it checked out as others have said. If their is an issue it will be recorded that you had it checked when new.
    That being said these transmissions are really clunky and sloppy. They do get better with some miles on though. Cant attest to the fluid change suggested above. But, I am on factory lube and it shifts a lot better than new. Still like a truck though.
  7. Sep 17, 2014 at 5:56 PM
    kpla51
    Fort Campbell
    seems like this is a more common problem after looking through that link gearcruncher sent. It might break in. It only feels like that if i shift and the rpms are at or above 2500 if i let them drop it goes in smooth.
  8. Sep 17, 2014 at 6:14 PM
    kpla51
    Fort Campbell
  9. Sep 17, 2014 at 7:52 PM
    Pigpen
    Dan
    Northwest Montana
    I always try to shift around 2000 to 2300, even when accelerating into traffic. It shifts more smoothly and the axle wrap effect is reduced.
  10. Sep 18, 2014 at 9:59 PM
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    Both my '08 and my '13 feel the exact same way... But no issues with either of them after 100k+ miles (other than that rough feel)
    I've read that the TRD and URD quickshifters "help" (but NOT "eliminate") with that roughness...
  11. Sep 20, 2014 at 5:59 AM
    kpla51
    Fort Campbell
    I made an appointment for the toyota dealer. Im not to worried about it since theres no grinding just that rough feeling. But id rather have it noted in case it turns into a problem.
