New master cylinder and booster no brake pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigpapaD93, Mar 7, 2017.
  1. Mar 7, 2017 at 1:44 PM
    BigpapaD93
    BigpapaD93 [OP] New Member
    2009 double cab Tacoma 4x4 4.0
    Stock
    I have a 2009 Tacoma 4x4 with the 4.0 v6 I've replaced the master cylinder booster rotors pads and calipers and I still don't have any break pressure and there's no aim in my lines anyone have any ideas as to my why breaks aren t work?
  2. Mar 7, 2017 at 1:47 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Did you adjust rear brakes?
  3. Mar 7, 2017 at 1:47 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    After replacing all that I would say you might have air in them.
    bluezzy likes this.
  4. Mar 7, 2017 at 4:21 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Sounds like air in the lines.
  5. Mar 7, 2017 at 4:39 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    Did you bench bleed the master cylinder before installing it?
    outlawtacoma and sparkystaco like this.
  6. Mar 7, 2017 at 4:42 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Do you have VSC?
  7. Mar 7, 2017 at 5:18 PM
    BigpapaD93
    Stock
    What's vsc?
  8. Mar 7, 2017 at 5:21 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    vehicle skid control
  9. Mar 7, 2017 at 5:23 PM
    BigpapaD93
    Stock
    Yeah I have abs
  10. Mar 7, 2017 at 5:31 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Vsc is not ABS
  11. Mar 7, 2017 at 5:32 PM
    BigpapaD93
    Stock
    I have traction control
    REDdawn6 likes this.
  12. Mar 8, 2017 at 4:48 PM
    magnetic4x4
    When you turn the key to run, look for the letters VSC on the dash. ABS keeps the wheels from locking up during hard braking. Traction control limits wheel spin during hard acceleration. And VSC can apply brakes at individual corners of the vehicle if it starts to slide by using the ABS. You could also have air trapped in the ABS hydraulic control unit.
    After re reading your original post, it sounds like you're saying you didn't have a brake pedal before you started replacing all those parts? I'd assume so since there's no reason to replace the master cylinder unless there was a problem. If that's the case, it's likely you have a dump valve that is stuck open in your ABS hydraulic unit.
    If you had a pedal before, and you replaced both calipers, do you have them on the right sides? The bleeder has to be above the brake line that bolts to the caliper or you'll never get the air out. I've seen it a couple times.
