New member 02 tacoma pre runner 4x4 conversion dilemma
Discussion in 'New Members' started by Junirol, Jul 15, 2021.
  1. Jul 15, 2021 at 5:14 PM
    Junirol
    Junirol [OP] Well-Known Member
    Rolando
    San Diego California
    05 Tacoma Prerunner SR5, 10 Tacoma 4x4 Off road
    E85 Flex fuel, TRD CAI, Magnaflow exhaust, TRD Supercharger
    Hello everyone, just wanna say hello and get my post count up so I can start selling some parts. I received an 02 Tacoma Prerunner ext cab 4 cylinder from my aunt last August, it had its fair share of issues with over 225k miles, hence when it was just given to me. She basically couldn't pass smog due to a check engine light, misfire in cylinder 1. Long story short it had burnt valves and I rebuilt the engine and slowly added some aftermarket parts. The first aftermarket mod was a lift kit, being I didn't want to spend a lot of money (already spend quite a bit on the engine) I opted for the Bilstein 5100 series shocks and 2881 OME springs, and a 1" block at the rears. It looked pretty good and leveled. Next was a set of wheels and tires, out with the 16" steelies and in with the TRD 16" Beadlock wheels (happen to be the last set in socal at that time) wrapped with 265/75/16 Yokohama geolanders. The truck looked totally different, to the point my auntie didn't even recognize it. I took the truck to fire roads and did some light off-roading. At this point, I was hooked on modding this truck and making it more capable. I swapped over a third member with a rear locker and wired it up, thanks to the information found here at Tacomaworld. My next goal is to do the 4x4 conversion, I have most of the parts I need to do it through my parts are kind of mismatched. I found a donor truck with the vacuum-operated ADD system, which I took the front diff axles/knuckles and VSV solenoids with lines. I found a transmission with a J shifter transfer case off a 4runner. I guess my biggest dilemma, has anyone tried to hook up / wire up a front diff with vacuum-operated ADD with a J-shifter transfer case. I've looked and haven't seen much, but since I got these pieces already I might as well try to see if I could make it work.
  2. Jul 15, 2021 at 5:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  3. Jul 15, 2021 at 5:31 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila likes this.
  4. Jul 15, 2021 at 5:34 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  5. Jul 15, 2021 at 6:28 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Very simple to wire the ADD solenoids, just need to hook it up to a switch. I believe @mechanicjon can point you the right way.
    I’ve done the swap on my truck so I’m happy to answer whatever questions you may have.
  6. Jul 15, 2021 at 9:19 PM
    Junirol
    Rolando
    Do I hook it up to the transfercase switch as a trigger for the solenoids to turn on and off?
  7. Jul 15, 2021 at 10:48 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I suppose you could, that's a bit above my paygrade. I'm more familiar with manual hub conversions rather than hooking up ADD. Most people who do this conversion forego hooking up the ADD system since it's more wiring and headache, although it should be simple to hook it up in the way you wish.
  8. Jul 15, 2021 at 10:52 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    tldr
    6 gearT444E likes this.
  9. Jul 15, 2021 at 11:54 PM
    Junirol
    Rolando
    lol
  10. Sep 8, 2021 at 2:38 PM
    Junirol
    Rolando
    /sigh I need to have 50 post of substance to sell something on the forums.
