New member! 14' taco lift project? Advise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Msloan64, Nov 7, 2018.
  1. Nov 7, 2018 at 9:28 PM
    Msloan64
    Msloan64 [OP] Member
    Tennessee
    14 tacoma TRDsport
    What's up everybody? My name is Matt. I'm new to the forum, kinda always been a reader though. I'm about to start a small-ish project on my 14' Tacoma v6 double cab TRD offroad 6spd manual(daily driver). First off, I wanna say Im not into die hard rock crawling, long travel, or anything major (wish I could be but I'm not rich). I hunt, fish, camp and ride decent mountain trails here in northeast Tennessee and southwest Virginia. Don't really wanna end up driving a log wagon and I definitely appreciate a smooth ride but I'm ok with the way well built lifted trucks drive. I've done butt loads of research and done some smaller lifts before on other trucks and I wanna get it right and just looking for a little input/advice. That being said... here's what I wanna do so far.....
    -6" BDS fox coilover lift (with rear db's: I know they aren't famous but my capability needs aren't that high)
    - 18x9 fuel assault wheels(mild offset/backspacing) with 35x12.50r18 toyo open country AT2
    - Re-gear diffs to 4.56 Yukon gears. Kit comes with new electronic lock solenoid etc...Currently at stock 3.73s (reputable shop installed)
    - quite a few other cosmetic upgrades
    OK, a few other random questions that I've researched....
    - Anybody out there run a setup like this with a 6spd manual?? Any clutch issues? Ever upgraded??
    - running a 6" lift/setup like this, is it best to upgrade to a one piece drive shaft?? Do most people do this with 6"?
    - what kind of abuse can the front stock axles take? Anybody upgraded?
    - are trac bars actually useful?
    - i don't like massively offset wheels but what is best offset to go with to avoid most if not all the rubbing that comes with 35" tires then having to trim and beat??? Best thing to do to completely alleviate all that notorious damn scrubbing with 6in lift and 35s????
    Wish I had time to do all the suspension work myself but most will be done by a shop(1,000+ overtime hours a year doesn't allow too much extra time). Any advise is appreciated. Also, any interjections to any other add on modifications/ideas to do during this project while she's tore apart is cool too.
    Bigdaddy4760 likes this.
  2. Nov 8, 2018 at 12:30 AM
    ovrlndkull
    ovrlndkull STUKASFK-HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    Bilstein 6112, Deavers, Method Standards, GDYR DuraTracs
  3. Nov 8, 2018 at 12:36 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Most just mall crawl so no. I would think a 1 piece with a good Double cardon joint and reset your diff pinion angle would be a whole lot better than your stock one. I mean people go to these with just a 3" lift
    - what kind of abuse can the front stock axles take? Anybody upgraded? They can take a hell of a lot of abuse. I don't get the full gist of this question
    - are trac bars actually useful? They can be again what is your thought process on this?
    - i don't like massively offset wheels but what is best offset to go with to avoid most if not all the rubbing that comes with 35" tires then having to trim and beat??? Best thing to do to completely alleviate all that notorious damn scrubbing with 6in lift and 35s???? 6in lift and 35s don't really rub nearly as much as on a 3" suspension lift. There are a few people that are around that run 35s go in the DB lift section and look. Take a look at those guys build threads.
    Biscuits likes this.
  4. Nov 8, 2018 at 1:30 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    2014 PovertyCharged & 2010 PovertyRunner
    Swiggity swangin' biggity bangin'
    Welcome to Tacoma World, Matt!
    I think there was an issue with the throw out bearing from the factory. Might want to check on that. Otherwise there are plenty of people here who have standard transmission Tacomas and are lifted or supercharged. As long as you aren't ridiculous with your shifting or ride the clutch into oblivion, your transmission will be fine.
    @ovrlndkull kinda hit the nail on the head. If the driftshaft doesn't vibrate post lift, don't worry about it. Basically, your driveshaft starts to vibrate when the angles of your drivetrain are too far out of tolerance. There are a couple of threads on TW that show how to measure your angles pre-lift (this is important) so that if you do experience driveshaft vibration, you know what angles your drive shaft needs to be to eliminate the vibration. It's a little more work but well worth avoiding the frustration.
    The CV axles? OEM are fine as long as you don't plow into a rock at 80mph.
    Depends on how they're built and connected. Traction bars are helpful in eliminating axle wrap, but I'd question their utility for any sort of moderate to serious offroading.
    According to BDS' website:
    35 x 12.50 w/18 x 9 and 4.5" Max. back spacing
    w/20 x 9 and 4.5" Max. back spacing
    *Trimming may be required*
    As I read it, if you go with the 18x9 you shouldn't have to trim, or any trimming necessary will be minimal. Larger than that you will. Best bet is to call BDS and verify.
  5. Nov 8, 2018 at 1:31 AM
    Bigdaddy4760
    Bigdaddy4760 Well traveled Older Than Dirt TTC # 059
    Maner
    Poolville Texas
    2017 Tacoma DCLB TRD OR, 1997 SC flatbed
    Welcome to TW!!
    :hattip: :cheers:
  6. Nov 8, 2018 at 1:37 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2015 DCLB 4x4 MGM
    Hellwig 2K helpers, LEER Shell, Tow mirrors, Bull Bar,
    Welcome aboard
  7. Nov 8, 2018 at 3:56 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Welcone to tw. Dont thonk u need a 6 inch lift to fit 35. Seen others do it. And yes alot of lifted mt 2nd gens on here. Check out manual transmission fan club. Or @EatSleepTacos has a build thread thats pretty cool. I would recomend talking to @HeadStrong Off-Road they are awsome to deal with.
  8. Nov 8, 2018 at 4:11 AM
    Msloan64
    Tennessee
    14 tacoma TRDsport
    Thanks guys, I appreciate all the input!:thumbsup:
  9. Nov 8, 2018 at 9:03 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    Trac bars can be very helpful in offroad applications. My first gen is going to get one here soon since I desperately need one. Axle wrap sucks and limits my truck a lot right now.
  10. Nov 8, 2018 at 12:28 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Welcome to TW!!
  11. Nov 8, 2018 at 12:38 PM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
  12. Nov 8, 2018 at 12:39 PM
    Taylorbarton1
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    Im running stock wheels with 2 or 2.5 inch spacers, i forget. no rubbing cab mount, spindle, or control arms.
  13. Nov 8, 2018 at 6:05 PM
    Msloan64
    Tennessee
    14 tacoma TRDsport
    @Taylorbarton1 If you don't mind me asking, what are you running in the rear? Dbs? I'm thinking of running leafpacks now with upgrade fox 2.0 Reservoir. What's the best alternative to DB's in the rear on the 6" lift? Will it make a huge difference to run leaf packs instead of dbs offroad?
  14. Nov 8, 2018 at 6:08 PM
    Msloan64
    Tennessee
    14 tacoma TRDsport
    @Taylorbarton1 what kind of front locker setup did you do? I'd love to incorporate that on the regear job. Front lockers are awesome offroad. From stock, my TRD OR has rear electric lock and A-trac system.
  15. Nov 8, 2018 at 6:15 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    There is no drop bracket for the rear. You gain your lift either by leaf springs, shackle flip with longer shackles, or blocks. You want to pair your shock length appropriately for the amount of suspension travel. Too short and it will limit down travel or droop too long and you'll bottom the shock out during up travel. Both can damage the shocks.
  16. Nov 8, 2018 at 6:18 PM
    Msloan64
    Tennessee
    14 tacoma TRDsport
    Sorry my bad, wrong terminology. I was attempting to refer to the blocks as "DB".
    ovrlndkull likes this.
  17. Nov 8, 2018 at 8:34 PM
    Taylorbarton1
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    The a track is basically a locker.
    rear the truck has stock leaf pack with the block that came with the kit plus. AAL. To make up for the saggy factory leaf pack.
  18. Nov 8, 2018 at 9:30 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2006 Pre-Runner TRD Sport
    2005 to 2012 Front End Mod 3" 810lb IronMan TOYO50C coils 4" MaxTrac Spingles 35.6"x 12.8" Amp Off-road A/T PPro Dodinson front struts and rear shocks Deaver AAL Custom 4" Aluminum single piece driveshaft 2012 Interior 2009 J-VIN Japanese made 1GR-FE Cali Off-road Anarchy PVD wheels 20"x10" etc.... Lol!
    Welcome to TacomaWorld, I'll give you fair warning before you start, people say cigarettes are addictive, no comparison to how addictive modding your truck will become, lol! :)
    Just my experience, went from 3" lift, ( small normal vibrations) to 7" lift, vibrations were so bad I parked it and had one piece aluminum driveshaft made. Problem solved. Look at it like this, if you pay a shop to do the work, a one piece driveshaft is alot cheaper than paying several hundred dollars every few years for a new carrier bearing. Plus your time dicking around with spacers and shims... Etc... My 4" aluminum one piece was $650 custom made at local shop.
    Just my $0.02 worth.
    Msloan64 [OP] likes this.
  19. Nov 8, 2018 at 9:41 PM
    jboudreaux1965
    Joseph
    Hub City
    Lol, 35's with 3" lift, yes it's been done before after chopping frame and fenders.With 33x11.50 with 3" coil lift, still had to swap to Trail Team wheels not to rub UCA's. To clear 35x12.8 tires had to go to 7" lift.
  20. Nov 9, 2018 at 3:16 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Atrac is nothing like a locker. It can somewhat work like one but not completely. There is a big difference, please don't spread information like this as it creates people thinking they have something they don't.
