new member 2000 Tacoma 5lug 2wd
Discussion in 'New Members' started by GRpufnstuf, Aug 12, 2018.
  1. Aug 12, 2018 at 4:27 PM
    GRpufnstuf
    GRpufnstuf [OP] Member
    george
    Tacoma 2wd/5lug/AC/AT/bench/RegCab/stock former delivery truck
    i took the hubcaps off and someone else bent the front bumper for me.
    Hey everyone,
    I've been creeping around the forum as a non member reading up on 5lug lifts and various builds.
    I'm getting close to starting my lift/build and thought I should say hello before I start asking the questions I can't find answers to.
    Pics coming soon
    SO, I recently bought a 2000 base model Tacoma. White, 2wd, 5 Lug, 2.4l, Automatic, Air conditioning, regular cab.
    It was a delivery vehicle for a local business and i watched it sit for many years without being used. Last registered in 2007 it only had 73,000mi on it
    I bought it and did a full replacement of all rubber hoses on the truck.
    Then a trans service, oil service, 2 new coil packs, new (used) fuel tank and pump, all filters, new brake fluid to go with the hoses, new left front brake caliper, and an AC service.
    Now it's driving fine with cold AC. All it technically needs is new shocks but...
    HELLO ;)
    plans :
    -early (1996) low profile front bumper conversion.
    -Doetsch Lift Spindles
    -Bilstein shocks front and rear (already have the 5100 rear)
    -Add A Leaf rear spring/leaf (already have from a PreRunner, I think it will fit.)
    -Planning on a tire in the 29" range, tall and skinny
    -2001-2004 15" steel wheels (already have)
    Them's the basics. I might also like -
    -PreRunner fenders and liners, or maybe a 2001-2004 sheet metal swap at the front?
    -big brake kit?\seen here - https://www.youtube.com/watch?v=uTCwWmbPV1I But i am having doubts about these Cadillac calipers fitting on the Doetsch spindle
    -I'm also confused about how much the Doetsch/fabtech spindles move the front wheels outward? I can't find any real world numbers and most people have custom rims with no specific adapter/ET/Backspace specs with this lift.
    I have also read that stock wheels won't work with the spindles but Doetsch implies they will.
    I did find a spec of 3 3/4" back space for these spindles but that's only one place and not well explained or documented. My 15" steelies have 4.5" or so
    And finally, I am having a lot of doubts about any of that up there as this truck drives like a dog. The slushbox AT is a bummer and the whole 2.4 package feels slow BUT it drives fine in slow LA traffic and heat. My other trucks, '73 Datsun 620 and '77 Dodge PowerWagon, do not have AC but are fun to drive.
    I suspect I'll have to re-gear if I start modding and going up in tire size. I'm not sure if I want to go that far
    Advice please
    BassAckwards and irayfz6 like this.
  2. Aug 12, 2018 at 5:29 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    StayinStock and irayfz6 like this.
  3. Aug 12, 2018 at 6:09 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  4. Aug 12, 2018 at 6:36 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    StayinStock likes this.
  5. Aug 12, 2018 at 8:05 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Welcome!
    buckhuntin-tacoma likes this.
  6. Aug 15, 2018 at 10:08 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you have questions goto the 5lug section and ask around there or read up alot of the good info that is there
  7. Aug 15, 2018 at 10:10 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    As for the spindle yes they widen the front track about 1 1/4” per side so it is wider then the rear after install.
    As for the big break im not sure, i have yet to get around trying to install the bigger calipers on my lift spindles
  8. Aug 15, 2018 at 10:12 AM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    I have the same one in sliver, the 2.4 AT is so slow. But love how compact and simple it is and fuel mileage is around 25mpg
