New Member 5 lug
Discussion in '5 Lug' started by aji5lug, Oct 10, 2014.
  1. Oct 10, 2014 at 9:36 AM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    Fat Bobs lift level,Long AA,Long rear shocks,Black Rock 15x10, BFG AT KO2 33X10.5X15, Performance accessories 3" Bbody lift. Rock Sliders, Black box removed, Front mudflap removed
    Hi All
    I wanted to Thank every body for all the great info I found searching this site for Lifting my 5 lug.
    I put Pic in my gallery for all to see and for info for people still looking.
    Details:
    Lift: Fat Bob's Garage long AA 2.75 front 1.75 rear w/ longer shocks
    WHeels: Black Rock 909B 15 x 10 / 4" BS / -38 offset
    Tires: Achilles 31 x 10.5 x 15 XMT
    Grill: Ebay Billet Aluminum plastic dipped black with suround
    Light bar: Ebay special
    Issues: Fat Bob Kit does not explain that you can not just turn the the strut 120 deg to fit the strut spacer, The spring mount on the bottom will hit the lower control arm and the brake line bracket will also hit on the backside
    Fix. Mount in the lower arm and use a pry bar to rotate the top mount 120 Deg Spray soapy water on the upper rubber grommet to help it slip around.
    The rubber may still bunch up a little on the end of the coil spring.
    Tire Rub: No caliper mod with this wheel, Tire will rub the black box.
    Fix: Remove the black box. and you will need to cut off the small front mud flap.
    Other than that there is no rubbing,
    Alignment: Alignment was not able to get caster camber back in.
    Fix: Need adjustable upper control arms or camber kit, I have not fixe this yet.
    Truck ruts a little on the highway, tires make noise :), braking sometimes will pull left or right probably because of the alignment, Going through puddle on one side will pull to that side.
    All in all looks like a new truck
    Thanks again evrybody
  2. Oct 10, 2014 at 2:22 PM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    Woops forgot the pics.
    Here they are before and after
  3. Oct 10, 2014 at 2:25 PM
    Fubarjonny
    Fubarjonny Well-Known Member
    Jonathan
    Orange County, CA
    5-LUG?
    Nice truck bro. I like that LED bar. How did you mount that on your bumper?
  4. Oct 10, 2014 at 3:11 PM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    Good question.
    As you know it is just plastic but if you look where it is mounted there is a metal bracket there.
    I located the holes then cut the bottom of the bracket with shears to make tabs to bend forward and I was able to run the bolt through the bumper and the tab bent from the bracket.
    The brackets are on the first surface below the grill. it is like a 45 from the front of the bumper.
    I did not take any pics of that but if you cant figure it out I will take some when I get a chance.
  5. Oct 10, 2014 at 5:59 PM
    Bob57
    Bob57 Well-Known Member
    Spencer Indiana
    2010 base
    Nice !
    Did the larger tire size effect your gearing that much?
    Oh, and Welcome
  6. Oct 11, 2014 at 6:14 AM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    No,
    it is a little more slugish but not bad.
    anything bigger would definitely need new gearing
  7. Oct 11, 2014 at 6:19 AM
    Half Caf
    Half Caf Well-Known Member
    Philadelphia, PA
    2009: 5 Lugs, 5 speeds
    Nice truck! Glad the forums were able to give you some help
  8. Oct 11, 2014 at 7:32 AM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    Here is a close up of where the LED bracket is on the bumper
  9. Oct 13, 2014 at 6:16 AM
    jtye
    jtye Well-Known Member
    DC
    08 Super White 5 lug
    Fog lights, fatbob's 5lug lift, Cragar 15x7, 31x10.5 Gen.Grabbers, Wet Okole
    Looks great, always nice seeing a new 5lugger
  10. Oct 13, 2014 at 6:31 AM
    hrspwr236
    hrspwr236 X-Runner Addict
    AZ
    2012 Barcelona Red X-Runner
    Python Alarm, Scangauge II, Valentine V1 w/ Blendmount, Black Front Badge, Volant CAI w/ Ram Air Scoop, TRD CBE, Doug Thorley Pipe Bomb, 19" TSW Montage, 245/45/19 Hankook V12, FLM, BHLM, 6k Heads & 3k Fogs, Undercover Tonneau Cover, Tacoma Bed Mat, Headrest Delete
    Looks nice, definitely a huge improvement over stock!
  11. Oct 13, 2014 at 12:04 PM
    Fubarjonny
    Jonathan
    Orange County, CA
    5-LUG?
    Looks good. What are your plans for the power cord?
  12. Oct 13, 2014 at 12:07 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    That's one of the nicest 5 lugs I have seen. Really think it looks nice with lift and no fender flares.
  13. Oct 13, 2014 at 4:08 PM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    I am not sure. It wont fit throuhg the grill so I am going to have to make another hole in the bumper with a gromet I guess.
  14. Oct 13, 2014 at 4:12 PM
    aji5lug
    aji5lug [OP] Member
    Miami
    2013 ext cab 5 lug
    Thanks.
    I dont like the fender flares either.
    I like the clean look without the flares.
    Its a bitch to keep clean, a little rain and it gets kicked up on the side of the truck but I will live with it.
