New member, DC Area, TRD Pro pre-modded
Discussion in 'New Members' started by Overland&UpMoutains, Oct 15, 2020.
  1. Oct 15, 2020 at 3:05 PM
    Overland&UpMoutains
    Overland&UpMoutains [OP] Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    I finally got a Tacoma! So pumped to get this truck. Found an amazing deal at a dealership of a tastefully modded TRD Pro MT.
    I found the previous owner on Instagram (@resilient.strength), and I’m sure he’s on here somewhere if anyone knows his name let me know.
    Took her off road (nothing crazy) on the first day!
  2. Oct 15, 2020 at 3:06 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  3. Oct 15, 2020 at 3:06 PM
    4x4_Taco
    4x4_Taco Well-Known Member
    FL
    Silver SR5 4x4
    Welcome! and congrats on the truck.
  4. Oct 15, 2020 at 3:15 PM
    FishnTx
    South East Texas
    ‘17 OR
  5. Oct 15, 2020 at 3:37 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila and FishnTx like this.
  6. Oct 15, 2020 at 4:09 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  7. Oct 15, 2020 at 4:10 PM
    Overland&UpMoutains
    Parker
    Deleware
    Where in VA are you? Looking to link up with some people in the area eventually.
  8. Oct 15, 2020 at 4:51 PM
    Motomandan
    Motomandan Well-Known Member
    Dan
    Mechanicsville MD
    2018 Double Cab TRD offroad
    Redarc brake controller in Caliraised panel with 2 extra switches, Accessorides remote start. Leer Topper w/ Rhino Rack
    Welcome from Southern MD!
  9. Oct 15, 2020 at 5:35 PM
    Overland&UpMoutains
    Parker
    Deleware
    Awesome! We have a place in Cambridge, not so far from you I’m assuming?
  10. Oct 16, 2020 at 7:45 AM
    Motomandan
    Dan
    Mechanicsville MD
    Not far about 18 miles of Chesapeake Bay in between though!
  11. Oct 16, 2020 at 11:52 AM
    Overland&UpMoutains
    Parker
    Deleware
    ahh your on the other side. Well I live in DC so your closer that way then
    what’s your go to spot for off road and or easy weekend camping?
  12. Oct 18, 2020 at 5:26 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW from Fairfax, VA!
