New Member Here! Need your welcoming opinions/facts!!
Discussion in 'New Members' started by 11PreRunner, Aug 13, 2014.
  1. Aug 13, 2014 at 11:47 AM
    11PreRunner
    11PreRunner [OP] Member
    Bossier City, LA
    White 11PreRunner TRD SoCal
    K&N performance air intake, Magnaflow exhaust, Doug Thorley headers, Black plasti dipped roof, BHLM, BFLM, BTLM, Satoshi grille, bull bar, 20x12 moto metal rrims on 33inch black bear all terrain tires with a 6" BDA kit with bilstein 5100 struts in the front.
    Im looking to lift my 2011 prerunner 2.7L double cab. I'm going with a 6" BDS kit and I want to put 35s on it with a 20x12 rim. The dude at the shop says that the 35s will rub like hell, and to go with a 33. Need your advice and reasons why a 35 will rub. (I'm not trimming anything)
  2. Aug 13, 2014 at 11:50 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What are you going to do for your gears? 2.7 DCSB and 6" lift sound like a nightmare
  3. Aug 13, 2014 at 11:58 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Are you going to wheel it or cruise the Walmart parking lot?
  4. Aug 13, 2014 at 12:09 PM
    11PreRunner
    Bossier City, LA
    Well considering its 2WD I wouldn't necessarily do too much wheeling. Maybe some trails but not too much. I'm considering a re gear ONLY if I get the 35s but I need to know if they'll fit without any trimming.
  5. Aug 13, 2014 at 12:24 PM
    geekhouse23
  6. Aug 13, 2014 at 12:34 PM
    Yota64
    Yota64 Professional Threadjacker
    With an aftermarket locker you could wheel all you wanted to, just saying.
    As for WHY it will rub, I assume just the wheel well is too small. 33s will affect your engine load and mileage a lot less than 35 as well. Pretty much gonna have to trim.
  7. Aug 13, 2014 at 12:41 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    It will rub on the street also but 35's are possible with minor trimming. The issue is when the wheels are turned completely either way & you hit a bump. The tire moves upward and will touch the lower, back corners of the fenders. The front mud flaps will have to be removed & plastic will need to be cut. Here is a pic of my lower fender....
  8. Aug 13, 2014 at 5:09 PM
    11PreRunner
    Bossier City, LA
    So will I just have to trim the black fabric/plastic shit inside the wheel well?
  9. Aug 13, 2014 at 5:14 PM
    Warputer
    2011 TRD Off Road
    Probably not.....mainly just the bottom corner of the outer color matched fender. I'm running wheel spacers on mine which made the body rub worse. But it was the only solution for me to run 16" wheels with a drop bracket 6" lift.
  10. Aug 13, 2014 at 5:15 PM
    Warputer
    2011 TRD Off Road
    ......and if you're not doing major off roading (suspension flex), even less trimming is necessary.
  11. Aug 13, 2014 at 5:16 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
    You could always save some money and do a MaxTrac spindle lift
  12. Aug 13, 2014 at 5:32 PM
    11PreRunner
    Bossier City, LA
    This BDS kit is running me $2500 with install. How much more for the MaxTrac?
  13. Aug 13, 2014 at 5:33 PM
    T4RFTMFW
  14. Aug 13, 2014 at 6:04 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
  15. Aug 14, 2014 at 7:34 PM
    11PreRunner
    Bossier City, LA
    so I could run 35 in tire with a 20s12 rim and do some trimming on the inside of the color matched lower fender? that'll prevent it from rubbing at full turn??
  16. Aug 14, 2014 at 7:53 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    You probably don't want to run 35s with a 4 cylinder. It won't be fun.
