New Member intro :)
Discussion in 'New Members' started by Michigan333, Feb 25, 2025.
  1. Feb 25, 2025 at 12:42 PM
    Michigan333
    Michigan333 [OP] Member
    Vinny
    2011 Red Tacoma 4x4
    Hey,
    I'm a new Tacoma owner, as of November, and am excited about joining Tacoma world. I bought a 2011 Tacoma, 4.0L Access Cab. its got a 6-spd manual and 4x4. I use it mostly as a work truck, but hoping to outfit it a bit to make it a tour truck for my band and do some camping around the country. Hoping to build out the bed in the next few months, and do some suspension work.
    This is the first Toyota I've ever owned, I had an 08 Audi a3 before (RIP :pout:) which i worked on extensively, so I'm hoping to do the same with the Tacoma without ruining it.
    Anyone have experience with either building out the bed or getting the suspension a little more sporty.... I would really appreciate some guidance!WhatsApp Image 2025-02-25 at 3.38.57 PM.jpg
  2. Feb 25, 2025 at 1:51 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    HondaGM and Finn-2187 like this.
  3. Feb 25, 2025 at 2:06 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    Welcome! I recommend you also post over in the second gen or suspension subforums for the most and best suggestions. Good luck!
  4. Feb 25, 2025 at 2:09 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW Vin.....
  5. Feb 25, 2025 at 2:18 PM
    ttng
    ttng New Member
    Thy
    Hello
    I would like to find console bracket tacoma 2010-2012. Like this pictures. If anyone has it, please contact me. Appreciate.
  6. Feb 25, 2025 at 3:55 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Welcome to TacomaWorld :proposetoast:
    Re: suspension upgrades. I wanted to cure the "washboard 'side-stepping" issue my truck occasionally had on the rougher Forest Service roads I travel to fish. I'd get it on slight climbs along the way that were eroded a bit. I installed Rancho RS5000 rear shocks and it cured it. They have valving which quickly self-adjusts to firm-up on surfaces like this or others which max-out the up/down travel limitsmof the shock. The damping returns to normal when things calm down. They work very well and they don't change the height in the back. If I towed more, or often carried heavy loads in the bed, I would probably have installed the KYB or Nivomat Self-Leveling shocks.
  7. Feb 25, 2025 at 8:13 PM
    Barok206
    Barok206 Well-Known Member
    2018 Cement Tacoma TRD OR
    Welcome!
