New member looking for the perfect tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jds4363, Mar 8, 2020.
  1. Mar 8, 2020 at 5:32 PM
    jds4363
    jds4363 [OP] New Member
    Joe
    New to this forum. Ive been stalking forums my whole life and this is actually my first post. Ive had three silverados with no complaints whatsoever. Looking for a 2nd gen Tacoma, What should I avoid? Im only posting this because I recently bought an 08 Rav4 for my wife just to discover that there is an outstanding recall for the excessive oil consumption. And finally, will I miss my silverados?
  2. Mar 8, 2020 at 5:44 PM
    storm_gray
    storm_gray Member
    Matias
    Duluth, MN
    2011 Mag Grey Manual Tacoma DCSB
    33's, 5100, kmc xd 18", TJM Winch, Demello bumpers,
    that’s a loaded question. in my opinion, you’re gonna want the v6, manual trans preferably. it is an underpowered motor and you will probably dislike it. there’s also not much you can do to make it better. 12-15 had the facelift. do you want a crew cab or an extendo? long bed? there’s a lot of options and variables in what you’re asking, but the thing is that toyota did not make a bad truck, you just need to find the right one for the job. let us know some more info on what you need the trük for.
  3. Mar 8, 2020 at 5:49 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
  4. Mar 8, 2020 at 5:54 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Avoid the ‘06, it’s known for head gasket failure. Check underneath any used Tacoma for rust, especially the frame.
    Marc70 likes this.
  5. Mar 8, 2020 at 6:10 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Can't tell you what to look for or what to buy....My 2015 Sport, V-6, auto, bought new, has been ABSOLUTELY trouble free from day one. I have not experienced on my 2nd gen Tacoma, Not ONE, of the issues ever mentioned on TW. Having said that, if you need a truck for heavy work, towing, hauling, etc, keep the Silverado. I use my Tacoma for light duty, getting groceries, towing my golf cart, local commutes etc. I also have a Ford Super Duty for doing the "work". Two different trucks for different purposes. You have to decide whether you need more, or less, or the same truck.
  6. Mar 8, 2020 at 6:15 PM
    MattR820
    MattR820 Active Member
    2011 Double Cab offroad
    You may not like the Tacoma if you're used to carrying a lot of weight, or towing anything really big. The Tundra is a better comparison to the silverado. That said, parking is easier with the Tacoma, and its (my opinion) a better choice for off roading than the Chevy. The comparison is really apples to oranges here.
  7. Mar 8, 2020 at 6:15 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Why don’t you just stay with the Silverado's.
  8. Mar 9, 2020 at 2:18 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    If you really use a full size you won't like a Tacoma.
    A Tacoma will be a downgrade for sure with creature comforts.
    Not sure I would do it if you have a Silverado you really like.
  9. Mar 9, 2020 at 6:18 AM
    DG92071
    DG92071 Well-Known Member
    2005 and early 2006. The problem was corrected 11/05. The problem is greatly exaggerated on the internet. They also have frame problems at the engine mount.
    t.hornstra likes this.
  10. Mar 9, 2020 at 6:26 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I bought my 2013 new and have really enjoyed owning it for the last 6 plus years with no plans to trade it in.
    Get 17 mpg avg, looks great, not meant for towing big stuff, a blast to drive off-road.
  11. Mar 9, 2020 at 7:08 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    What should you avoid when it comes to a Tacoma? How about avoiding this forum, be prepared to spend $ on stuff.
    Tah-koh-mah and DavesTaco68 like this.
  12. Mar 9, 2020 at 7:48 AM
    jds4363
    Joe
    Thanks for the replies. I rarely use my half ton for what it’s made for anymore, every once in awhile I’ll hook a trailer up to it for moving light equipment. Since rust is taking out the Silverado it seems like the double cab Tacoma is the best replacement for my needs.
  13. Mar 9, 2020 at 7:53 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    Depending on which silverado you had, you'll definitely miss the power and sound of a V8 chevy engine. All you'll hear from the tiny Tacoma is a what they call the "taco tick". The tacoma is more of a "play truck" then anything else. It's great for going off-road as it has great maneuverability in tight areas with it's great turning radius and narrow wheel base. However, the tacoma is notorious for rusty frames, driveline vibrations, weak ball joints, weak front wheel bearings, unknown vibrations from 30-45 mph, then some at 50-60 mph, weak leaf springs, head gasket issues in earlier gens, squishy brakes, squishy clutch on the manual, and many other issues. But some of those things can be fixed or toyota will fix them under a recall or service campaign of sorts, and some things will go away and come back for unknown reasons. I have a vibration I still can't figure out at highway speeds and I've learned to just live with it, I've tried everything, balance tires, driveshaft balance, replaced u-joints, replaced every tie rod, control arm, ball joint, suspension component I can think of, etc and still got some vibration, but now it's at a different speed and different rpm. I just stopped chasing it and learned to live with it. Anyways...
    Plenty of recalls and TSB's for rusty frames and rusty leaf springs and many other items. Just do a quick search on here and you'll find all you want to know about the Tacoma. Overall it's not a bad truck, just be aware of what you can live with and without.
  14. Mar 9, 2020 at 7:55 AM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Double cab 4.0 4x4 - even without the work you’ll feel like the Tacoma is weaker. Cause it is.
    But it’s meant to be a light duty truck with great off road capabilities. If that’s what you’re looking for you can get what i mentioned above. TRD trim or not, up to you and depends on if you want to mod it anyways. If you plan on switching out suspension and lifting then just go base 4x4 4.0 V6 double cab.
    welcome!
  15. Mar 9, 2020 at 7:57 AM
    Spizike231
    Jesse
    Sacramento, CA
    Oh.. and if you haven’t started looking yet be ready for our notorious resale value.
  16. Mar 9, 2020 at 7:58 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Its going to be a downgrade in everyway compared to your Silverado, but if you can live with the fact that your trading down for a smaller, underpowered truck and you really really don't need or want a full size then you might like it.
