New Member, old Tacoma!
Discussion in 'New Members' started by 99TACO4X2, Jul 23, 2018.
  1. Jul 23, 2018 at 12:34 PM
    99TACO4X2
    99TACO4X2 [OP] New Member
    1999 Green Toyota Tacoma PreRunner V6 3.4L
    Hello Taco Peeps! I have a 99 Tacoma V6 3.4L 4x2. I'm trying to pin down an issue I've been having for a few weeks now. I try to do as much myself as I can. I just read several posts about 'Intermittent starting issues'. I recently replaced the 'Ignition Lock Cylinder', worked great for about a week, then started having trouble starting again. From what I've from you guys, seems like it may be the negative battery Cable, or starter solenoid contacts.
    When I try to start it, I get one click, but doesn't turn over. Inside overhead light is on. I can jiggle the key several times, and try to start multiple times, then it finally starts. it seems very random.
    irayfz6 likes this.
  2. Jul 23, 2018 at 3:39 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    ODNAREM, 99TACO4X2[OP] and irayfz6 like this.
  3. Jul 23, 2018 at 3:39 PM
    Paint pig
    Paint pig Well-Known Member
    2013 trd off road 4x4, mag grey
    welcome
  4. Jul 23, 2018 at 7:01 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Hopefully a 1st Genner will have an answer for you.
  5. Jul 23, 2018 at 10:56 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
    buckhuntin-tacoma likes this.
  6. Jul 23, 2018 at 11:13 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Welcome to TW!
  7. Jul 24, 2018 at 9:40 AM
    99TACO4X2
    Thanks for the 'welcomes', much appreciated! Hopefully I'll get some feedback from my fellow 1st-Genners!
  8. Jul 26, 2018 at 6:53 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  9. Jul 26, 2018 at 7:00 AM
    1DVS-BSTD
    1DVS-BSTD is probably confused
    The Corn Is Pretty Good Here
    '03 TRD Off-Road, '22 Poverty Spec
    881's, Nitrochargers, Dakars, SR8's, Duratracs
    Are the connections clean on the battery? Also make sure they are tightened. I'd wager it isn't a starter problem if it won't even turn over. Sounds to me like a bad connection somewhere. Or maybe your battery needs to be replaced. I'd check voltages too and make sure you're good there.
    Anyway, welcome to TW! 1st gen is best gen. :D :burnrubber:
  10. Jul 26, 2018 at 9:10 AM
    99TACO4X2
    Thanks for the reply, keep them coming! My Battery is only a couple years old, I keep the connections clean. I will dbl check for tightness. I have been doing different things, to get it to start, I've noticed the last thing I've tried seems to be working, but odd. If I turn the steering wheel to lock it, before I get out, when I get back in the next morning to start, if I put the key in, turn it to ACC, then unlock the steering wheel, it's starting on the 1st try. I've done that last 3 days. Is there a connection between the steering wheel locking/unlocking, and the ignition lock cylinder?
  11. Aug 6, 2018 at 2:29 PM
    99TACO4X2
    I have replaced the Ignition Lock Cylinder, thought that was it, worked great and cranked 1st try, for a week or 2, then started not wanting to crank again...ugh. I checked the battery connections, they are clean and on tight. I started putting the steering wheel in lock, then turning key to ACC, unlock steering, then sometimes it would start. Now, I have steering in lock position, and I jiggle it back an forth 3 or 4 times, then unlock, and it's been starting 1st try again. This is driving me crazy, can't figure out what's causing that. What is the link/connection between the steering lock/unlock, and the ignition? Has anyone had this issue or similar?
