New member TRD problem starting
Discussion in 'New Members' started by Wpashe, Jan 20, 2021.
  1. Jan 20, 2021 at 12:30 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    Hey,
    New to the group and hope I can find some help here.
    I have a 2001 TRD that I really like. Apparently it doesn’t like me anymore.
    I was at Lowe’s a few months ago and came out to leave and when I tried to start it, it spun over for about 10 seconds before starting. Never done that before. Always started right up. From then on it was the same every time I started it. I put it in a local shop that usually does my work and they kept it over a month and couldn’t find the problem. I brought it back home and a couple weeks later it would not start at all.
    I had it hauled to a different shop and they had it 3 weeks and called me today to pick it up. They can’t find the problem but did find out how to start it.
    They told me to turn the key on for about 30 seconds then the check engine light would come on and then it would start.
    Ive never heard of anything like this.
    Anyone have any idea?????????
  2. Jan 20, 2021 at 12:31 PM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    I would start by checking the grounded connections. I'm assuming you have gone through battery, ignition, scanned for codes, etc.
  3. Jan 20, 2021 at 12:43 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila and Wpashe[OP] like this.
  4. Jan 20, 2021 at 12:49 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I installed a new battery and trust that the shops scanned the codes. It’s had a check engine light for s while because of a sensor on the converter but it has not caused s problem that I know of.
  5. Jan 20, 2021 at 12:52 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I always start these sorts of things by connecting a jumper cable to the negative post of the battery and the other end to the engine block. Grounds can be tricky and the large loads from a starter can do weird things.
    I've seen it a number of times when you have voltage and continuity in all the right places but once you try and start and pull all the current it goes open and nothing happens.
  6. Jan 20, 2021 at 12:53 PM
    TacomaUSA
    PA
    Find a schematic for the grounds on your vehicle. How's the overall rust?
    You can also unhook the battery for a while to reset the codes and try to start it then. Sounds like it has something to do with the check engine light
  7. Jan 20, 2021 at 12:56 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    There is no rust on the truck at all. It only has 139,000 miles.
    I did that when I changed the battery and it made no difference.
    Black DOG Lila likes this.
  8. Jan 20, 2021 at 12:59 PM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    I will definitely do the jumper cable thing. I know what a problem ground can be.
  9. Jan 20, 2021 at 1:02 PM
    TacomaUSA
    PA
    Goodluck! Let us know what you find out
    Wpashe[OP] likes this.
  10. Jan 20, 2021 at 1:58 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  11. Jan 21, 2021 at 12:50 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  12. Jan 23, 2021 at 8:59 AM
    Wpashe
    Wpashe [OP] Member
    William
    Tacoma TRD
    None
    Small update to the problem. As long as the check engine light is on, the truck will start.
