New Member with 3in lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dstock, Feb 11, 2013.
  1. Feb 26, 2013 at 9:11 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    I believe also if you try to run a 285 tire on a stock wheel you'll be rubbing the UCA, wheel spacers would fix that. I have 17s with a 285 70 did the cab mount chop and TC UCA s and no more rubbing, had to do some trimming but that's it. Got to do a little trim trim.
    Brett
  2. Feb 26, 2013 at 9:15 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ^^ same here.
  3. Mar 11, 2013 at 1:00 PM
    dstock
    dstock [OP] Well-Known Member
    David
    Camp Lejeune
    2011 Tacoma double cab v6 4x4
    URD short throw shifter, halo projection headlights, 8000k hids in headlights and foglights. Made my own color matched satoshi with homertaco mesh.
    Do you guys know if it is possible to run stocks wheels with 285/70 tires on a 3 inch lift with wheel spacers? If so how big of spacers would I need?
