new member, with problem.
Discussion in 'Technical Chat' started by rebelheart, Apr 18, 2013.
  1. Apr 18, 2013 at 1:44 PM
    rebelheart
    rebelheart [OP] New Member
    Philip
    2001 2.4 Tacoma
    2001 2.4 Tacoma has idle problem. Idles at 1000 to 1500rpm. Replaced MAF, throttle sensor, O2 sensor, cleaned the flap in the throttle body. Honestly, I am at the end of ideas. Currently replacing head gasket. Came to find out, it is a Calf emissions truck even though we bought it new in 2001. Any ideas would be appreciated. What are the chancs of it being the computer?
  2. Apr 18, 2013 at 1:53 PM
    jwynn
    jwynn New Member
    Lakeland, Florida
    13 PreRunner TRD Sport
    I also have a 2001 Tacoma 2.4 V6 PreRunner and had the exact same problem. A family friend and previous Toyota mechanic took the truck apart and also ran a computer check. He determined that the truck which was made according to California emissions specs had a melted O2 sensor. He ended up replacing the sensor and catalytic convertor and I have not had the problem sense. This occurred roughly a year ago and the truck idled at about 2000 rpm. Hope this helps, but remember to take it to a place with a good computer to check the whole system. I first took it to a place who replaced several parts that did not need to be changed and cost me $$$. Also, because the truck is set to California standards, the emissions sensors and such are very sensitive.
  3. Apr 22, 2013 at 8:52 PM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    one problem with both posts, is that toyota does not make a 2.4, they make a 2.7l 4 cylinder and a 3.4L V6. Idk if ya'll had a typo or not. :notsure: Also, my 3.4l V6 idles that high when it is cold, after it warms up it drops back down to normal. It isn't the computer. I would take it to the stealership or to a well known/trusted mechanic and have them check the system on it and see why it is doing what it's doing.
  4. Apr 22, 2013 at 8:58 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Wrong. Toyota does make a 2.4L 4 cyl. It's called a 2rz-fe.
  5. Apr 23, 2013 at 1:26 PM
    mac424205
    Mathew
    Chelsea
    My mistake. I thought it was an older motor than what's in ops vehicle.
    EDIT: I guess I meant for the year of the ops vehicle....
