New member with Tacoma mystery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nana 4x4, Apr 13, 2021.
  1. Apr 14, 2021 at 1:37 AM
    Nana 4x4
    Nana 4x4 [OP] New Member
    Sheila
    2008 manual Tacoma 4x4
    None
    Thank you all so much for the quick responses yes my Tacoma does have a clutch bypass button tried it and it didn't work, though the light came on for it. It does have the little plastic button under the clutch pedal that they refer to as a starter safety device meaning if the clutch isn't all the way to the floor, it won't start. So I went through and tightened down my battery terminals as tight as I can get them and and the ground bolts, after making them all shine like a new penny. I also discovered it does have the what Toyota refers to as engine immobilizer system ., So a extra thanks to dk Crew, for your suggestion. Who knew , what a security system ! Anyways so after cleaning everything up, going through the reset got in, stood on the clutch and my baby fired up ! Course it could have just been the way I talked so sweet to it before I put in the key ...LOL. thank you all so much for all the great suggestions and input I'm so glad to be a member !!
  2. Apr 14, 2021 at 2:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Listen very carefully and when you turn the key do you hear one small click and then nothing?
    If so it is probably the starter solenoid.
    It can be rebuilt for about 40 dollars and a hour of your time.
    Then after several attempts it will start and sound normal for a bit.
    If so then the starter solenoid has worn burned contacts and can be repaired in an hour or two for less than 40 dollars.
    You can buy the contacts and plunger new from Nations Starter and Alternator for about 30 - 35 bucks. Much cheaper than hundreds for a rebuilt POS from Autozone etc.
    https://www.nationsstarteralternator.com/Starter-Rebuild-Kits-s/37.htm
    Check this video for rebuilding the solenoid on the starter.
    https://www.youtube.com/watch?v=qwokxzjlYcQ&feature=emb_logo
    deanosaurus and BassAckwards like this.
  3. Apr 14, 2021 at 4:26 AM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Make sure to use chunky peanut butter instead of creamy
  4. Apr 14, 2021 at 6:45 AM
    Waasheem
    Waasheem
    2007 xrunner
    Sounds like your issue was loose and dirty battery. It might have been the Toyota security system. I’m trying the battery terminal felt pads for the first time, got Noco brand. It’s too early to say if they’re helping or not.
    Your battery probably has a low state of charge. You could just drive for a half hour or better hook up a battery charger to get it topped off.
    Glad you got it figured out and started!
  5. Apr 14, 2021 at 2:27 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    My old Cadillac had a habit of battery terminals coming slightly loose. Seemed to always have enough contact to run lights, radio, etc... But as soon as I tried to start it, everything would go dead.
