New member/
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mikeymoses, Oct 31, 2015.
  1. Oct 31, 2015 at 8:46 PM
    Mikeymoses
    Mikeymoses [OP] New Member
    Austin, Ar
    Tacoma
    Lift and tires
    My brake peddle goes soft while at a stop, yeah I thought that too,master cylinder? No it has no leaks any where full of fluid and all pads and shoes are new...took it to the Dodge Dealership i purchased it from they said its fine . now keep on mind this happened only some times ..wth ???
  2. Oct 31, 2015 at 9:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Welcome to the Forum, Internal Master Cylinder Leak.
  3. Nov 1, 2015 at 5:47 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That happens when you get older...
    Seriously: It could be an internal leak, but it could also be a little air in the system. What year? If a few years old it would benifit from a pressure flush anyway. It will get rid of any air or water in the system.
    Mikeymoses[OP] likes this.
  4. Nov 1, 2015 at 6:58 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Welcome to TW.
    Try flush and bleed as Jimmyh suggested.
  5. Nov 1, 2015 at 8:55 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW. So it feels firm and then goes soft after sitting at a stop? Or does it feel soft in general. If it is the later I'd make sure the rear drums are properly adjusted, can make a big difference. Also if going to a dealer, I would go to a Toyota dealer that is framiliar with the truck, not Dodge.
